2811 nde/netflow support
cfajardo1_2
hello,
is cisco 2811 supported on the netflow/nde config?
thanks.
rajivrajan1
Level 3
Level 3
yes
router#configure terminal
router(config)#interface
router(config-if)#ip route-cache flow
router(config-if)#exit
router(config)#ip flow-export destination x.x.x.x 9996
router(config)#ip flow-export source
router(config)#ip flow-export version 5
router(config)#ip flow-cache timeout active 1
router(config)#ip flow-cache timeout inactive 15
Make sure your IOS version
hi,
what should be my minimum ios version?
thanks
