2811 restart after service-policy
yatisspor
Hello;
We have a lot of branches. Below config is the same for all. But one of them has a problem. When i apply this config, it gets locked then it restart. Any idea?
access-list 161 remark policy1
access-list 161 permit ip any host X.x.x.x
access-list 161 remark policy2
access-list 161 permit ip any X.x.x.x X.x.x.x
access-list 161 remark policy3
access-list 161 remark policy4
access-list 161 remark policy5
class-map match-any Voip
description Voip Packet
match dscp ef
class-map match-all Class2
description important
match access-group 161
interface Serial0/0/0
no fair
policy-map MAPPOL
class Voip
priority percent 30
class Class2
set dscp af41
bandwidth percent 30
class class-default
fair-queue
random-detect
service-policy output MAPPOL
max-reserved-bandwidth 100
interface ATM0/1/0
bandwidth 256
delay 2100
no atm ilmi-keepalive
pvc 0/35
vbr-nrt 256 256
broadcast
Peter Paluch
Hi Murat,
If your router restarts itself when applying a service policy then there is either a problem with your IOS or with the RAM in your router.
Make sure that the you either have the same IOS as on the other routers, or that you are using the newest stable IOS if possible (not the T-train if not necessary, as the T-train might be unstable).
I have ecountered similar spontaneous restarts in two cases: either the amount of RAM was insufficient for all features currently running on a router, or the RAM was damaged. Can you investigate these two scenarios?
Best regards,
Peter
Joseph W. Doherty
Don't believe it, alone, should crash your router, but why are you using "max-reserved-bandwidth 100"?
When you router restarts, any indication in show ver why the router restarted? Any crash file?
As Peter notes, selection of IOS can be important. What exactly are you running on this 2811?
