2911: dynamic NAT problem
Jaaazman777
Level 3
Level 3
Hello!
We have strange problem with our 2911 router.
After replacing one router with another with the same IOS 15.2(2) and the same configuration, dynamic NAT stopped working.
from sh ip nat translation we cannot see any dynamic translations, only static
here is the configuration
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 192.30.1.1 255.255.255.0
ip nat inside
no ip virtual-reassembly in
crypto ipsec client ezvpn fw2 inside
interface FastEthernet0/0/1
description WAN1
ip address 1.1.1.166 255.255.255.252
ip nat outside
duplex auto
speed auto
crypto ipsec client ezvpn cl1
access-list 100 deny   ip 192.30.0.0 0.0.255.255 10.0.0.0 0.255.255.255
access-list 100 permit ip 192.30.0.0 0.0.255.255 any
route-map nat-wan1 permit 10
match ip address 100
match interface FastEthernet0/0/1
ip nat inside source route-map nat-wan1 interface FastEthernet0/0/1 overload
connect auto
group <***> key ***
mode network-plus
peer 2.2.2.2
acl 103
username ***@domain.local password ***
xauth userid mode local
access-list 103 permit ip 192.30.6.0 0.0.0.255 10.100.1.0 0.0.0.63
access-list 103 permit ip 192.30.5.0 0.0.0.255 10.100.1.0 0.0.0.63
the ip address on FastEthernet0/0/1 is a default gateway
router-2911#sh ip route
Codes: ...
Gateway of last resort is 1.1.1.165 to network 0.0.0.0
here is dome information from debug ip nat detailed
NAT: API parameters passed: src_addr:192.30.1.57, src_port:0 dest_addr:195.13.252.210, dest_port:0, proto:6 if_input:Vlan55 pak:2BB4D628 get_translated:1
NAT: API parameters passed: src_addr:192.30.1.54, src_port:0 dest_addr:65.55.223.30, dest_port:0, proto:6 if_input:Vlan55 pak:2BB4D628 get_translated:1
10 Replies 10
rizwanr74
Level 11
Level 11
Hi there,
Your nat seemed to be fine even though you don't need a route-map in the overload statement.
This will do the nat as well just an FYI...
ip nat inside source list 100 interface FastEthernet0/0/1 overload
Your WAN "FastEthernet0/0/1" what kind of circuit it is? because your default-gateway "1.1.1.165" is not on the same subnet.
Are you able to ping this ip "1.1.1.165" ?
please update.
thanks
Hi, rizwanr74
I am able to ping 1.1.1.165
It seems to be on the same subnet as 1.1.1.166, the subnet is 1.1.1.164/30
isn't it?
I also tried ip nat inside without acl 100.
We have two WAN links, that's why, we need two WAN ip nat translations with route-maps, that matches the external interfaces
Have you enabled "ip routing" on the router?
Your default-gateway pushes everything to other WAN interface, just for temporally change your default-gatway to interface in qustion.
thanks
Message was edited by: Rizwan Mohamed
if routing was disabled he wouldn't have the output he gave us in the sh ip route and furthermore NAT needs routing to function because the router first looks for a route to destination then nat the source IP.
Regards.
Alain.
Hello!
As far as I know ip routing is enabled by default on routers since long time.
So, in my router it is also enabled by default.
The decision about the default gw is controled by BGP
router bgp 55555
bgp log-neighbor-changes
neighbor 1.1.1.165 remote-as 7777
neighbor 1.1.1.165 description wan1
neighbor 2.2.2.253 remote-as 7777
neighbor 2.2.2.253 description wan2
address-family ipv4
  neighbor 1.1.1.165 activate
  neighbor 1.1.1.165 route-map default-in in
  neighbor 2.2.2.253 activate
  neighbor 2.2.2.253 prefix-list default-in in
route-map default-in permit 10
match ip address prefix-list default-in
set local-preference 200
ip prefix-list default-in seq 5 permit 0.0.0.0/0
in initial post you gave us the output from debug ip nat detailed and it was working so is the communication not working or
just the dynamic entries are not shown in the NAT table ?
Regards.
Alain.
The dynamic NAT is not working, so the dynamic entries are not shown in the NAT table.
At the same time, the static NAT works fine, we have several static NAT for port translation.
I checked the debug ip nat detailed output from the other routers, where dynamic NAT works fine.
The output is not the same as here.
the "good" logs are as following
NAT*: i: tcp (10.40.7.16, 51463) -> (75.131.31.5, 25) [44269]
NAT*: s=10.40.7.16->200.200.200.178, d=75.131.31.5 [44269]
hi,
could you modify your route-map and give it a try?
set interface FastEthernet0/0/1
modifying the route-map is indeed a good suggestion( thanks for pointing it out) but I would not replace the match statement with a set as it is needed for natting on multiple interfaces but rather modifying the match interface to match ip next-hop.
Regards.
Alain
Jaaazman777
Level 3
Level 3
Hello!
It seems, like the problem is in crypto ipsec client ezvpn cl1, configured on interface FastEthernet0/0/1
when I replace it, the dynamic NAT begins to work
I have no ideas, how can ezvpn influence the NAT it this case.
On the previous router with the same config and IOS everything worked fine...
