2911 licensing
whanson
Level 2
Level 2
If customer buys without cube license, I assume I have to purchase and actually apply the license.  Is that correct?  thx as ever
Reza Sharifi
Yes, you would need to buy the license and load the file on the router and install it.  It is very small file.
Yes, you need to buy cube license & then apply that to get the features in that license.
You could also check with licensing@cisco.com
