2911 vdsl ios 15.7 no internet and no DHCP on local clients
tmx666
MFWS-2911-R2#enable
Password:
MFWS-2911-R2#sh conf
Using 3347 out of 262136 bytes
! Last configuration change at 17:04:14 UTC Mon Jul 20 2020 by tom
version 15.7
service password-encryption
hostname MFWS-2911-R2
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
enable secret 5 $1$kOFr$f65d5AtQ/TihZS3zylNJ81
enable password 7 046F190717394D5D5B4B
no aaa new-model
no process cpu extended history
no process cpu autoprofile hog
ip dhcp excluded-address 172.16.1.1 172.16.1.10
ip dhcp pool **bleep**
network 172.16.1.0 255.255.255.0
default-router 172.16.1.1
dns-server 172.16.1.100 172.16.1.101
lease 9
ip name-server 1.1.1.1
ip name-server 1.0.0.1
ip cef
no ipv6 cef
voice-card 0
vxml logging-tag
license udi pid CISCO2911/K9 sn FCZ161420G0
hw-module pvdm 0/0
hw-module pvdm 0/1
username tomf password 7 08155E4F110104044059
username tom privilege 14 secret 5 $1$CP8A$pWzROyjBvjIXd.1RMYZOi0
redundancy
controller VDSL 0/1/0
no cdp run
interface Embedded-Service-Engine0/0
no ip address
shutdown
no cdp enable
interface GigabitEthernet0/0
ip address 10.0.0.2 255.0.0.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
no mop enabled
interface GigabitEthernet0/1
ip address 172.1.1.1 255.255.255.0
ip nat inside
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/2
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
shutdown
duplex auto
speed auto
no cdp enable
interface ATM0/1/0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0/1/0
no ip address
interface Ethernet0/1/0.101
encapsulation dot1Q 101
ip nat outside
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer0
description TT business
mtu 1432
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
no ip virtual-reassembly in
encapsulation ppp
ip route-cache policy
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
no cdp enable
keepalive 30
ppp authentication chap callin
ppp chap hostname 01432507490@talktalkbusiness.net
ppp chap password 7 04715E3F5A0F1B795A3C57
ppp direction callout
ppp ipcp address accept
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 10.0.0.0 255.0.0.0 10.0.0.1
no service-routing capabilities-manager
snmp-server community public RO
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
shutdown
line con 0
exec-timeout 0 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh stopbits 1
line vty 0 4
password 7 09585C08011D1601595E
login local
transport input ssh
scheduler allocate 20000 1000
end
MFWS-2911-R2#
It has passed PPPoe as i can ping any address
10.0.0.2 is my other network it can pass data to that no problem and vice versa
However anything plugged into Gi0/1 gets no IP and when it was handing out IPs it had no internet access
Any ideas?
make the changes marked in bold:
version 15.7
boot-start-marker
boot-end-marker
no aaa new-model
lease 9
ip cef
no ipv6 cef
voice-card 0
vxml logging-tag
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
no cdp run
no ip address
shutdown
no cdp enable
ip nat inside
duplex auto
speed auto
no cdp enable
no mop enabled
--> ip address 172.16.1.1 255.255.255.0
ip nat inside
duplex auto
speed auto
no cdp enable
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
shutdown
duplex auto
speed auto
no cdp enable
interface ATM0/1/0
no ip address
shutdown
no ip address
ip nat outside
interface Dialer0
mtu 1432
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
keepalive 30
ip http server
ip http path flash:
--> access-list 1 permit 172.16.1.0 0.0.0.255
--> access-list 1 permit 10.0.0.0 0.0.0.255
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
line aux 0
line 2
no exec
line vty 0 4
login local
transport input ssh
end
version 15.7
boot-start-marker
boot-end-marker
no aaa new-model
lease 9
ip cef
no ipv6 cef
voice-card 0
vxml logging-tag
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
no cdp run
no ip address
shutdown
no cdp enable
ip nat inside
duplex auto
speed auto
no cdp enable
no mop enabled
ip nat inside
duplex auto
speed auto
no cdp enable
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
shutdown
duplex auto
speed auto
no cdp enable
interface ATM0/1/0
no ip address
shutdown
no ip address
ip nat outside
interface Dialer0
mtu 1432
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
keepalive 30
ip http server
ip http path flash:
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
line aux 0
line 2
no exec
line vty 0 4
login local
transport input ssh
end
Spot on once again ta.
The 887 wont run past 30 meg where as this 2911 is getting the full bandwidth now ta
