2921 Router will support BGP by default?
SHIBI V DEV
We wanted to configure VPN in 2921 router and configure routing with BGP.
  I have installed  evaluation license for DATA and SECURITY . But now we ordered only SECURITY license fro the router.
For VPN we need Security license , but BGP will be enabled by default or do we need to install DATA license for that?
For instance, we always buy SECK9 license, and it's always included BGP.
JohnTylerPearce
Level 7
Level 7
Offers the security features found in Advanced Security IOS image on ISR 1800,2800 and 3800 e.g. IKE v1 / IPsec / PKI, IPsec/GRE, Easy VPN w/ DVTI, DMVPN, Static VTI, Firewall, Network Foundation Protection,GETVPN etc.
The above is from Cisco's site.
I deal with ISR G1's and ISR G2's on a daily basis, and I promise with the HSEC license, you will be able to run BGP.
So i need to buy only SECK9 license , for BGP  - DATA license is not not required ?
Thanks john for the information. I will let you know after installing license.
