2950 error message
olakunle06
please i need urgent solution to the log below.i need to access the switch.ports not blinking at all but fan on.what do i do
C2950 Boot Loader (C2950-HBOOT-M) Version 12.1(11r)EA1, RELEASE SOFTWARE (fc1)
Compiled Mon 22-Jul-02 17:18 by antonino
WS-C2950-24 starting...
Base ethernet MAC Address: 00:17:5a:1c:77:40
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 373 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 4752384
flashfs[0]: Bytes available: 2989056
flashfs[0]: flashfs fsck took 7 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading "flash:/c2950-i6q4l2-mz.121-22.EA6.bin"...#############################################################################################################################################################################################################
File "flash:/c2950-i6q4l2-mz.121-22.EA6.bin" uncompressed and installed, entry point: 0x80010000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 21-Oct-05 01:59 by yenanh
Image text-base: 0x80010000, data-base: 0x80568000
Initializing flashfs...
flashfs[1]: 373 files, 4 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 4752384
flashfs[1]: Bytes available: 2989056
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[1]: Initialization complete.
Done initializing flashfs.
POST: System Board Test : Passed
POST: Ethernet Controller Test : Passed
ASIC Initialization Passed
%Error: initializing transceiver port Fa0/1
%Error: initializing transceiver port Fa0/2
%Error: initializing transceiver port Fa0/3
%Error: initializing transceiver port Fa0/4
%Error: initializing transceiver port Fa0/5
%Error: initializing transceiver port Fa0/6
%Error: initializing transceiver port Fa0/7
%Error: initializing transceiver port Fa0/8
%Error: initializing transceiver port Fa0/9
%Error: initializing transceiver port Fa0/10
%Error: initializing transceiver port Fa0/11
%Error: initializing transceiver port Fa0/12
%Error: initializing transceiver port Fa0/13
%Error: initializing transceiver port Fa0/14
%Error: initializing transceiver port Fa0/15
%Error: initializing transceiver port Fa0/16
%Error: initializing transceiver port Fa0/17
%Error: initializing transceiver port Fa0/18
%Error: initializing transceiver port Fa0/19
%Error: initializing transceiver port Fa0/20
%Error: initializing transceiver port Fa0/21
%Error: initializing transceiver port Fa0/22
%Error: initializing transceiver port Fa0/23
%Error: initializing transceiver port Fa0/24
Giuseppe Larosa
hello Olakunle,
first of all using an attachment file would have been a better choice.
I'm afraid to give you bad news: it looks like the switch is not able to access the ports.
Try to power off. Let it powered off for some time.
Then try again.
If still it suffers of the same problem if you have a valid contract for it ask for a replacement unit.
Hope to help
Giuseppe
Leo Laohoo
Please try to avoid cross-posting. One post is sufficient.
