Private VLAN configuration assistance
cisco24x7
Level 6
Level 6
Is it possible to have both primary VLAN and members VLAN residing on the same line card of the Catalyst 6509? For example:
interface FastEthernet1/1
description Firewall port
switchport
switchport private-vlan mapping 527 528-529
switchport mode private-vlan promiscuous
no ip address
spanning-tree portfast
interface FastEthernet1/2
description c2811
switchport
switchport private-vlan host-association 527 528
switchport mode private-vlan host
no ip address
speed 100
duplex full
interface FastEthernet1/3
description c3640
switchport
switchport private-vlan host-association 527 529
no ip address
LAB6500F#sh mod
Mod Ports Card Type Model Serial No.
1 48 48-port 10/100 mb RJ45 WS-X6148-45AF SAL09190GSZ
3 48 48-port 10/100 mb RJ45 WS-X6148-45AF SAL09190GK8
6 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL092644DU
Mod MAC addresses Hw Fw Sw Status
1 0013.c4e9.1d48 to 0013.c4e9.1d77 3.0 8.3(1) 8.5(0.46)RFW Ok
3 0013.c3f9.0b64 to 0013.c3f9.0b93 3.0 8.3(1) 8.5(0.46)RFW Ok
6 0013.7f0d.5110 to 0013.7f0d.5113 4.4 8.1(3) 12.2(18)SXF1 Ok
Mod Sub-Module Model Serial Hw Status
1 IEEE Voice Daughter Card WS-F6K-FE48-AF SAL09190GVH 1.5 Ok
3 IEEE Voice Daughter Card WS-F6K-FE48-AF SAL091802HK 1.5 Ok
6 Policy Feature Card 3 WS-F6K-PFC3B SAL09253X5X 2.1 Ok
6 MSFC3 Daughterboard WS-SUP720 SAL09253VHE 2.3 Ok
Mod Online Diag Status
1 Pass
3 Pass
6 Pass
LAB6500F#sh ver
IOS (tm) s72033_rp Software (s72033_rp-ENTSERVICESK9_WAN-M), Version 12.2(18)SXF14, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Thu 08-May-08 01:32 by kellythw
Image text-base: 0x40101040, data-base: 0x42DCEA30
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-ENTSERVICESK9_WAN-M), Version 12.2(18)SXF14, RELEASE SOFTWARE (fc1)
LAB6500F uptime is 8 weeks, 4 days, 19 hours, 47 minutes
Time since LAB6500F switched to active is 8 weeks, 4 days, 19 hours, 46 minutes
System returned to ROM by power cycle at 23:02:18 UTC Wed Jul 15 2009 (SP by power on)
System restarted at 23:07:38 UTC Wed Jul 15 2009
System image file is "disk0:s72033-entservicesk9_wan-mz.122-18.SXF14.bin"
With this configuration, both f1/2 and f1/3 is put down because:
Sep 14 17:29:05.836: %PM-SP-3-ERR_INCOMP_PORT: 1/2 is set to inactive because 1/1 is a promiscuous port
Sep 14 17:29:38.762: %PM-SP-3-ERR_INCOMP_PORT: 1/3 is set to inactive because 1/1 is a promiscuous port
In order for PVLAN to work properly, I have to move the configuration of F1/2 and F1/3 to a different line card.
Is this a requirement in Catalyst 6500?
Thanks.
yagnesh_tel
Hi David,
Yes, that's the limitation.
See 'Private VLAN Configuration Guidelines and Restrictions' This also list modules on which this limitation applied.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/pvlans.html#wp1143064
Jon Marshall
David
As Yagnesh has said it is a limitation of the 6500. However it is a limitation based on port groupings on the line card. The port groupings for the WS-X6148-45AF are -
Number of ports: 48
Number of port groups: 4
Port ranges per port group: 1-12, 13-24, 25-36, 37-48
so you should be able to configure it on the same line card but not within the same port group.
Jon
Is it safe to assume that Cisco 3550 and 3750 does not have this limitation? Thanks.
Correct. There is no such limitation for them.
