2nd level Router does not have access to the internet
Amir Eskandari
Hi there,
I have a test lab for my VMWare.
for the routing between different network in the lab I used GNS3.
in the project I have five routers.
Router "Mgmt" is connected to my Physical server NIC and the NIC is connected to my physical router
Router "Mgmt" is good and can ping 8.8.8.8
my first test router is "VMNet3"
I am able to ping any port on the "Mgmt" from "VMNet3"
But cannot ping 192.168.1.1 (the IP address of the physical router/ Gateway of the Physical Router)
Please refer to the enclosed topology and the config file.
I am wondering what am I missing in the config of the VMNet3?
Thank you in advance
Amir Eskandari
I fixed it by adding NAT in the MGMT Router
Building configuration...
Current configuration : 1753 bytes
! Last configuration change at 11:38:56 UTC Tue May 31 2016
upgrade fpd auto
version 15.0
hostname Mgmt
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
ip source-route
ip cef
no ipv6 cef
redundancy
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface GigabitEthernet1/0
ip address 192.168.1.123 255.255.255.0
ip nat outside
ip virtual-reassembly
negotiation auto
interface Ethernet2/0
ip address 10.10.14.2 255.255.255.252
ip nat inside
duplex half
interface Ethernet2/1
ip address 10.10.10.1 255.255.255.252
ip nat inside
duplex half
interface Ethernet2/2
no ip address
shutdown
duplex half
interface Ethernet2/3
no ip address
shutdown
duplex half
interface Ethernet2/4
no ip address
shutdown
duplex half
interface Ethernet2/5
no ip address
shutdown
duplex half
interface Ethernet2/6
no ip address
shutdown
duplex half
interface Ethernet2/7
no ip address
shutdown
duplex half
router rip
version 2
network 10.0.0.0
network 192.168.1.0
ip default-gateway 192.168.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface GigabitEthernet1/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
access-list 100 permit ip any any
control-plane
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
Mgmt#
