3.6.1.2 Packet Tracer - Skills Integration Challenge
joep82
Remote
Serial0/0/0   209.165.201.22 YES manual up down
Protocol down can't seem to get it up?
8 Replies 8
on a serial links, one side usually needs the 'clock rate' command, do you have that configured ?
Which side should the clock rate be set on ISP-3 or the BRANCH router?
And any specific rate number?
configure it on the ISP router:
interface Serial0/0/0
clock rate 64000
Clock rate set on ISP router
Still on Branch Router protocol down for the s0/0/0
Hi @joep82,
Remote
Only as discard, in the guide that shows the ip for that interface is 209.165.201.2, but you assigned the ip 209.165.201.22.
Try changing the ip and assigning the one specified in the guide.
For better reference, could you send us the exercise?
Problem is with the Branch Router, here is the exercise.
Hi @joep82,
Could you send the pkt with your progress to check the settings?
Hi @joep82,
You must make 2 changes in your configurations:
1-In ISP-3, in the interface s0/0/0 must be configured PPP also
2-The authorized user in ISP-3 is BRANCH, so you must change the name to the SBO router
ISP-3
ISP-3(config)#interface Serial0/0/0
ISP-3(config-if)#encapsulation ppp
ISP-3(config-if)#ppp authentication chap
Small Branch Offices
SBO(config)#hostname BRANCH
