3 BGP Network Statements
Ibrahim Jamil
Level 6
Level 6
Hi Freinds why these 3 BGP Network Statements ?? the 2nd one isn't enough to advertize all as its 10.0.0.0 router bgp 65112 bgp router-id 10.255.241.104 bgp log-neighbor-changes network 0.0.0.0 network 10.0.0.0 network 10.4.0.0 mask 255.252.0.0 thanks all
Giuseppe Larosa
Hello Ibrahim,
BGP now has a default of no auto-summary.
This means that an exact match for the prefix is needed to advertise in BGP
Example:
router bgp 100
no auto-summary
network 10.0.0.0.0
The first command advertises 10.0.0.0/8 only if the prefix is present in the IP routing table in any form.
The second command advertises 10.4.0.0/22 again if present in IP routing table.
BGP can advertise both if both are present in IP routing table, it does not think in a classful way.
The protocol is classless and looks for prefixes and their prefix lengths.
If you want to create an aggregate and to advertise only that you need
router bgp 100
aggregate-address 10.0.0.0 255.0.0.0 summary-only
Hope to help
Giuseppe
Giuseppe Larosa
Hello Ibrahim,
Example:
router bgp 100
no auto-summary
network 10.0.0.0.0
router bgp 100
Hope to help
Giuseppe
thanks Giuseppe
