3548xl Speed/Duplex Mismatch Question
gobigblue
Is there any way from the console of the 3548xl to tell if the device connected to a particular port is speed/duplex mismatched?
All the ports on the switch are set to 100/Full and I want to ensure all the desktops are as well.
Collin Clark
CRC errors are usually an indication of a mismatch.
show interface | i CRC
You can also see what devices are running at half duplex.
show interface | i half
Hope that helps.
Are there any free windows based tools that lets you see what IP's are on what port?
