3600 IOS Upgrade
maple
We are receiving the following message after trying to boot to the
latest IOS 12.3(15) with IP Plus.
Error : zip decompress failed
invalid compressed data--format violated
uncompression of the image failed
This is our current versions of IOS and ROM. Is there an incompatibility
with the the version of ROM and the IOS we are trying to upgrade to?
IOS (tm) 3600 Software (C3620-I-M), Version 12.3(5c), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 14-Apr-04 15:40 by cmong
Image text-base: 0x60008B00, data-base: 0x60C86000
ROM: System Bootstrap, Version 11.1(19)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
uunet-router uptime is 19 hours, 44 minutes
System returned to ROM by reload at 18:01:02 EST Tue Jul 12 2005
System restarted at 18:06:10 EST Tue Jul 12 2005
System image file is "flash:c3620-i-mz.123-5c.bin"
cisco 3620 (R4700) processor (revision 0x81) with 61440K/4096K bytes of memory.
Processor board ID 08877089
R4700 CPU at 80MHz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
8192K bytes of processor board PCMCIA Slot0 flash (Read/Write)
20480K bytes of processor board PCMCIA Slot1 flash (Read/Write)
do you happen to have a new PCMCIA flash card inserted ?
You might want to try and format your flash, I don't know if this can be done from ROMMON though on the 3600 (I think the 'tftdnld' command asks you to erase the flash and formats it). If that doesn't work, and if you have another 3600 available, you could format the flash there and then reinsert it in the original router.
HTH,
GP
The 3600 series does not support formatting the flash and we do not have any other routers that support that card. We have tried erasing the flash every time we loaded the OS (several time, several versions). IP (not plus) works fine as you can see from the show ver. We are trying to load 12.3.15, IP Plus.
