Content engine error message
adnan
I am configuring a content engine model CE-511-K9, when I issue the command "wr mem" the follwing message appears. I was wondering if any one has seens this. The ACNS version is Release 5.2.3 (build b9 Nov 2
9 2004)
Version: ce511-5.2.3
Jul 7 01:59:57 xxxx-CE510-01 exec_copy: %CE-CLI-3-170012: Copy rmproxy.cfg
to SS failed. status = (1,1). Ignore if you didn't change RealProxy config
Jul 7 01:59:57 xxxx-CE510-01 exec_copy: %CE-CLI-3-170013: tar -czPf /tmp/re
al/adm_b_db.tar.gz /tmp/real/adm_b_db >& /dev/null failed: status = (1,2)
al/con_r_db.tar.gz /tmp/real/con_r_db >& /dev/null failed: status = (1,2)
alserver/adm_b_db.tar.gz /tmp/realserver/adm_b_db >& /dev/null failed: status =
(1,2)
alserver/enc_r_db.tar.gz /tmp/realserver/enc_r_db >& /dev/null failed: status =
(1,2)
Jul 7 01:59:57 xxxx-CE510-01 exec_copy: %CE-CLI-3-170012: Copy eimserver.in
i to SS failed. status = (1,5). Ignore if you didn't change Websense-server conf
ig
Jul 7 01:59:57 xxxx-CE510-01 exec_copy: %CE-CLI-3-170012: Copy config.xml t
o SS failed. status = (1,5). Ignore if you didn't change Websense-server config
Jul 7 01:59:57 xxxx-CE510-01 exec_copy: %CE-CLI-3-170012: Copy websense.ini
to SS failed. status = (1,5). Ignore if you didn't change Websense-server confi
g
Jul 7 01:59:57 xxxx-CE510-01 exec_copy: %CE-CLI-3-170013: tar -czPf /local/
local1/WebsenseEnterprise/EIM/blockpages.tar.gz /local/local1/WebsenseEnterprise
/EIM/BlockPages >& /dev/null failed: status = (1,141)
smalkeric
Level 6
Level 6
This is a known issue. These messages are seen when the "Write mem" command is executed on a CE with ACNS version 5.2.3. These messages do not imply anything and can be ignored. Do you see any problems occuring in your setup due to these messages? If you want to avoid getting these messages you can upgrade the ACNS to the latest version.
Thanks for the reply, I don't see any problems with the setup but was just concern with the mesaages that I get on "wr mem" command. I will try with the latest ACNS version and see what happens.
