3700 Router boot issues
jeffjmadsen
Confreg 0x1242 was entered in ROMmon instead of
0x2142!  Router doesn't boot and the "SYS" light just flashes.  Is the hardware now
a paperweight or is there a way to recover it?
Reza Sharifi
Can you get back to Rommon and change it back to 2142?
Unfortunately no, otherwise I would have corrected it.  I never get to any prompt.  I seems to start to boot then just hangs.  Is there any reset on the motherboard that your are aware of?
hi jeff,
i would suggest to open a Cisco TAC case and have the switch RMA'd.
