3825 IOS upgrade
josephp
Hello folks, just need a little guidance as to how to resolve my IOS upgrade issue on my 3825. I have the following statement on my running config.
"boot system flash c3825-advipservicesk9-mz.124-15.T6.bin"
I keep getting the following message when I try to boot to that image (Reload)
console by console.
%SYS-3-IMAGE_TOO_BIG: 'flash:c3825-advipservicesk9-mz.124-15.T6.bin' is too large for available memory (50954264 bytes).
%SYS-6-READ_BOOTFILE_FAIL: flash:c3825-advipservicesk9-mz.124-15.T6.bin File read failed -- Not enough space.
Attached is a copy of the show version & show flash.
TS1#sh flash
-#- --length-- -----date/time------ path
1 32658112 Apr 18 2007 20:45:34 -04:00 c3825-advipservicesk9-mz.124-3g.bin
2 1038 Aug 16 2007 22:11:20 -04:00 home.shtml
3 1826 Aug 16 2007 22:11:22 -04:00 sdmconfig-38xx.cfg
4 113152 Aug 16 2007 22:11:22 -04:00 home.tar
5 1475584 Aug 16 2007 22:11:24 -04:00 common.tar
6 6141952 Aug 16 2007 22:11:32 -04:00 sdm.tar
7 861184 Aug 16 2007 22:11:40 -04:00 es.tar
8 793739 Aug 16 2007 22:11:24 -04:00 256MB.sdf
9 1684577 Apr 18 2007 20:55:48 -04:00 securedesktop-ios-3.1.1.27-k9.pkg
10 398305 Apr 18 2007 20:56:08 -04:00 sslclient-win-1.1.0.154.pkg
11 3873 Dec 19 2007 20:35:30 -05:00 pre_autosec.cfg
12 51491936 Dec 03 2008 23:08:10 -05:00 c3825-advipservicesk9-mz.124-15.T6.bin
32526336 bytes available (95653888 bytes used)
TS1#
TS1#sh ver
Cisco IOS Software, 3800 Software (C3825-ADVIPSERVICESK9-M), Version 12.4(3g), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 06-Nov-06 05:10 by alnguyen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
TS1 uptime is 2 hours, 33 minutes
System image file is "flash:c3825-advipservicesk9-mz.124-3g.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3825 (revision 1.1) with 747520K/38912K bytes of memory.
Processor board ID <Removed>
2 FastEthernet interfaces
2 Gigabit Ethernet interfaces
16 terminal lines
2 Channelized (E1 or T1)/PRI ports
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
125440K bytes of ATA System CompactFlash (Read/Write)
TS1#
Thanks in advanced I appreciate your help.
16 Replies 16
