4 byte AS number support for Cat4500 switch
PD92
Hello Team,
I have Cat4500 switch on the following version: 12.2(53)SG2, RELEASE SOFTWARE (fc1)
Requesting your help in confirming if this model/version has the support for 4 byte AS-number.
If no then can you please point me towards the 1st release from which this is supported.
Thanks in advance.
Prathmesh D
Mark Elsen
 -  Ref : https://content.cisco.com/chapter.sjs?uri=%2Fsearchable%2Fchapter%2Fcontent%2Fen%2Fus%2Ftd%2Fdocs%2Fios-xml%2Fios%2Fiproute_bgp%2Fconfiguration%2F15-e%2Firg-15-e-book%2Firg-4byte-asn.html.xml&platform=Cisco%20Catalyst%204900%20Series%20Switches
                Check Table 4
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
pman
Here example how to check if the switch / router support with 4 byte AS number :
 2 byte AS numbers in the range of 1-65535
 4-byte AS numbers in the range of 65536 to 4294967295.
You can verify if your switch / router support when you configure the AS number:
this one support:
R1(config)#router bgp ?
  <1-4294967295>  Autonomous system number
  <1.0-XX.YY>     Autonomous system number
this one not support:
  <1-65535>  Autonomous system number
