4 port Switch module
devans
Community Member
I have a 1720 router with a 4 port Ethernet switch in one of the modules and the router does not recognize it. The LED for the module comes on and states WIC 1 OK, but the router does not recognize it. I upgraded the IOS on it to the latest. Doesn't this router support this card?
5 Replies 5
scottmac
Level 11
Level 11
Are you trying to address the individual ports as separate interfaces, or addressing all four as a group (i.e., VLAN 1)?
As long as you're addressing the group as a single routed entity, then it sounds like a dead port.
I'm pretty sure you cannot address the individual ports as four seperately routed interfaces.
Good Luck
Scott
devans
Community Member
I am supposed to be able to see them as separate interfaces, i.e.
interface FastEthernet1
switchport access vlan 2
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
I would then create a VLAN as in this config and assign it an IP.
My whole purpose in doing this is I have a DSL line to backup the Internet T1.
I have another router that I have the same card and the router identified the interfaces just fine, this does not for some reason.
See below what the SH TECH shows.
WIC/VIC Slot 1:
Unknown
Daughter card-Version 4 TLV Cookie Format
Hardware Revision : 1.0
Part Number : 73-8958-01
Board Revision : D0
Deviation Number : 0-0
Fab Version : 01
PCB Serial Number : FOC10041AAG
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Top Assy. Part Number : 800-24817-01
Connector Type : 01
Unknown Field (type 00CF): 00 16 C8 E8 AF E0
MAC Address block size : 20
Product (FRU) Number : WIC-4ESW
CLEI Code : IPMED00BRA
This shows up on Inventory section
NAME: "WIC/VIC 1", DESCR: "Unknown"
PID: Unknown , VID: 1.0, SN: 3843086023
What code are you running? Looking at the data sheet:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00801c749d.html
I see that it needs either 12.3XC code, or 12.4T.
devans
Community Member
12.3(19), shouldn't that work? Or it must be of the C type or 12.4?
Nope, 12.3(19) is mainline and according to the IOS map, it does not look like it branched off that XC train. You either need a 12.4T or a 12.3(2)XC or later in the same train.
Please rate helpful posts.
