4 T1 slow upload, file corruption download
www.itnetcr
Hello Experts,
I have 4 T1's connected to my cisco 2800.
I'm having problems uploading. It only gives me 3megs when it should be 5.5.
My downloads get corrupted when they are over 200Mbps in size.
I have been reading a lot, and I can't find the answer. Only thing close is this command:
(config)int multilink
(config-if)#bandwidth 6056
Will this work? I understand that the bandwidth command is only for routing protocols and not related to the actual bandwidth.
I'm attaching the config, show version, show interfaces.
* Very important note, the ISP brought another router (not Cisco Brand) and everything worked perfectly, so it definetely is the router.
Thank you,
Randall
John Blakley
From first looks, you have a lot of CRC errors on your Serial interfaces. You may want to hard-code the speed and duplex for these lines. This will slow your speed down tremendously. The second is that I see "ip nat outside" on your multilink interface, but I don't see a corresponding "ip nat inside" on any of the interfaces. I'm not sure if this would cause the problem you're experiencing, I would suspect the CRC errors more than anything.
Did you post a complete config?
John
HTH, John *** Please rate all useful posts ***
