4331 Internet Access
gherkin12
Good morning all.
I'm currently in the process of upgrading from a 2921 to a 4331 (there probably isn't a great deal of difference between the two however I managed to acquire one lol)
anyhow i'm struggling to get a internet connection. I copied the config from the 2921 to the 4331 thinking that might work however although i can ping items on the vlans I have created I can't seem to pickup an IP address from the ISP.  Below are the settings from the interface (4331):
interface GigabitEthernet0/0/0
 description **INTERNET CONNECTION**
 ip address dhcp
 ip nat outside
 ip access-group 199 in
 negotiation auto
 ip virtual-reassembly
and this one is from the 2921 (which works)
 description **INTERNET**
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no mop enabled
would anyone be able to point me in the right direction please.
TIA
make the changes/additions marked in bold:
Current configuration : 3521 bytes
version 15.5
no platform punt-keepalive disable-kernel-core
hostname RT4331
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
clock timezone PST -8 0
clock summer-time PST recurring
ip dhcp bootp ignore
ip dhcp excluded-address 192.168.2.100
ip dhcp excluded-address 192.168.2.101
ip dhcp excluded-address 192.168.2.103
ip dhcp excluded-address 192.168.2.2
--> ip dhcp excluded-address 192.168.2.1
ip dhcp excluded-address 192.168.3.1
ip dhcp pool vlan 200
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 192.168.4.12
ip dhcp pool vlan 300
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
subscriber templating
voice-card 0/4
no watchdog
license udi pid ISR4331/K9 sn FDO2130203X
redundancy
mode none
vlan internal allocation policy ascending
ip address dhcp
ip nat outside
--> no ip access-group 199 in
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
description **WIRELESS ACCESS POINT**
switchport access vlan 200
interface GigabitEthernet0/1/1
switchport access vlan 300
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
description **DELL R710 IDRAC**
switchport access vlan 400
interface GigabitEthernet0/1/4
description **DELL R710 GBe INTERFACE**
interface GigabitEthernet0/1/5
description **PI HOLE DNS SERVER**
interface GigabitEthernet0/1/6
description **IRACING RIG**
interface GigabitEthernet0/1/7
interface Service-Engine0/4/0
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
interface Vlan200
description **WIRELESS NETWORK**
ip address 192.168.2.1 255.255.255.0
ip nat inside
ntp broadcast client
interface Vlan300
description **NOT SURE YET**
ip address 192.168.3.1 255.255.255.0
ip nat inside
interface Vlan400
description **STATIC ADDRESSES**
ip address 192.168.4.1 255.255.255.0
ip nat inside
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
--> no ip route 0.0.0.0 0.0.0.0 192.168.0.1 254
--> ip route 0.0.0.0 0.0.0.0 174.72.148.1 254
--> no ip route 0.0.0.0 0.0.0.0 68.96.211.1 254
--> ip route 0.0.0.0 0.0.0.0 GigabitEThernet0/0/0 dhcp
ip access-list extended RESTRICT_ENTRY_INTERNET
deny tcp any any eq 22
deny tcp any any eq telnet
--> no access-list 1 permit any
--> access-list 1 permit 192.168.2.0 0.0.0.255 any
--> access-list 1 permit 192.168.3.0 0.0.0.255 any
--> access-list 1 permit 192.168.4.0 0.0.0.255 any
--> no access-list 199 deny tcp any any eq 22
--> no access-list 199 deny tcp any any eq telnet
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
14 Replies 14
Georg Pauwen
post the full running configuration of your 4331 router...
gherkin12
Current config attached - apologies @Georg Pauwen for not attaching it in the first place 🙂
Hi @gherkin12 ,
ACL 199 blocks all traffic coming in on the Internet facing interface. Bear in mind that there is an explicit "deny any any" at the end of an ACL. This is the reason you can't get an IP address from your ISP.
version 15.5
hostname RT4331
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
import all
voice-card 0/4
no watchdog
redundancy
mode none
ip address dhcp
ip nat outside
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
interface Vlan200
ip nat inside
interface Vlan300
ip nat inside
interface Vlan400
ip nat inside
no ip http server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
Hello
First of all remove the access list from the 4331 wan interface then test again, if that dosent work, find out the mac addresss of the 2921 wan interface and set that same mac address to the 4331 wan interface and then test.
4331
int gig0/0
mac address (xxxx.xxxx.xxxx) < old mac addresss of 2921>
Lasty remove all the static default routes and append just this  -
ip route 0.0.0.0 0.0.0.0 gig0/0 dhcp
Kind Regards
Paul
gherkin12
Thank you guys, so removed the acl part and also did the bits in bold from you suggestion @Georg Pauwen .  From the router I can now ping 8.8.8.8 which is great (again thanks for that).  The only bit I couldn't get to work correctly was the:
access-list 1 permit 192.168.x.0 0.0.0.255 any
I couldn't get it to work by putting any at the end, I ended up with
Now that leads me onto the next question, would that have issues with that gateway getting access to the internet?
sorry about that, my fault.
Th access list needs to be:
Is Internet access working for your LAN clients ?
Hello
So just to confirm, you rtr now has ip address allocation and can reach the internet?
sh ip int brief
What do you mean by gateway - do you mean your lan clients?
Kind Regards
Paul
gherkin12
No problem @Georg Pauwen managed to get that part sorted 😉  and in response for your last part, no the clients can't seem to get to the internet.  they can ping the gateway (so in the computer i'm testing it on 192.168.4.1) but can't get to 8.8.8.8 for example.
@paul driver the list of the "int br" command.  Please note that the reason GE0/0/0 is down is because it isn't currently connected, however when it is connected it is up (i need to disconnect and reconnect to gain comms to the internet lol).  By gateway I mean the VLAN address - so from my client 192.168.4.13 i'm using 192.168.4.1, VLAN400.
RT4331#sh ip int br
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0/0   68.224.131.177  YES DHCP   down                  down
GigabitEthernet0/0/1   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0/2   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/1/0   unassigned      YES unset  down                  down
GigabitEthernet0/1/1   unassigned      YES unset  down                  down
GigabitEthernet0/1/2   unassigned      YES unset  down                  down
GigabitEthernet0/1/3   unassigned      YES unset  down                  down
GigabitEthernet0/1/4   unassigned      YES unset  down                  down
GigabitEthernet0/1/5   unassigned      YES unset  down                  down
GigabitEthernet0/1/6   unassigned      YES unset  up                    up
GigabitEthernet0/1/7   unassigned      YES unset  down                  down
Service-Engine0/4/0    unassigned      YES NVRAM  up                    up
GigabitEthernet0       unassigned      YES NVRAM  administratively down down
Vlan1                  unassigned      YES NVRAM  administratively down down
Vlan200                192.168.2.1     YES NVRAM  up                    down
Vlan300                192.168.3.1     YES NVRAM  up                    down
Vlan400                192.168.4.1     YES NVRAM  up                    up
RT4331#
post the current running configuration again with the changes you have implemented...
gherkin12
there we go @Georg Pauwen (apologies in the delay)
Hello
How are your clients connecting to the network?
Are they directly connected to the rtr or vis a access switch?
Do your lan clients receive ip address allocation, can they ping their own D/G and the wan ip address of your rtr.
Kind Regards
Paul
Hey Paul
my bad, i was using my DNS server address which currently isn't connected so when changed to 8.8.8.8 it now works.  apologies for that, school boy mistake that one.  Thank you very much guys for your help 🙂
can you ping 8.8.8.8 when sourced from a Vlan interface "
ping 8.8.8.8. source 192.168.2.1
