4331 Router WAN DHCP Issue
Alex Pfeil
Level 7
Level 7
Are there any issues with NAT and getting an IP address on an outside interface?
Alex
if you get a dynamic IP address, use the interface for overloading:
interface GigabitEthernet0/0/0
ip address dhcp
ip nat outside
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
I was looking more for a caveat or issue with renewing the IP address.  An example would be that we have a permit ip any any, do we need to specifically deny the DHCP address from NAT?
Alex
to 'permit ip any any' is usually not a good idea. Specify the local networks you want to have translated.
With regard to DHCP, for WAN connections this is not a problem, as ISPs usually provide infinite leases.
Make sure your default route specifies 'dhcp':
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
