4451X VLAN interface
westj
Visitor
I am trying to configure VLAN interfaces on a 4451X and have issue. I can configure subinterfaces, but I want to configure a real VLAN interface like this:
B12_3925(config)#int vlan 11
*Jan 11 21:17:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan11, changed state to down
B12_3925(config-if)#IP add 192.168.100.1 255.255.255.0
Am I missing something? This should be very simple.
Thank you
Peter Paluch
The 4451-X is a router, therefore, working with VLANs is different to switches. Creating an interface Vlan would only make sense if you had a switching module installed into this router and had some of its interfaces configured as switchports in the particular VLAN. Otherwise, the only way to work with VLANs attached to the routed interfaces of this router is to create subinterfaces.
Keep in mind: A router can have multiple routed interfaces and each of them can terminate an independent set of VLANs. To a router, simply saying "VLAN 11" does not mean anything, as that VLAN can be used on multiple routed ports and their subinterfaces. That's why the style of interface Vlan is not used with routers without switching modules installed because it is ambiguous.
Feel welcome to ask further!
Best regards,
Peter
Peter Paluch
Best regards,
Peter
Makes sense, the switch module is on order.
Thank you
You are welcome! 🙂
Best regards,
Peter
