4506 vlan split
dragec
I have 4506 switch with two ip addresses on default vlan, primary and secundary, different C classes. I want to split this on two vlans. Can I make second vlan and move one IP address to this vlan and then configure bridge between thost two vlans and then slowly move client PCs ports to second vlan? What would configuration looks like? Just put bridge-group 1 command onto these two VLANs?
Thanks!
thisisshanky
Level 11
Level 11
You can change all the client ports at one go, using interface range command.
int vlan 1
ip add y.y.y.y <--- current primary ip
int vlan 2
no shut
ip add <--- move the secondary ip here.
vlan 2
name Secondary vlan
interface range fa 1/24 - 48
switchport mode access
switchport access vlan 2
spanning-tree portfast
Approx downtime would be approx 1 minute (even less depending upon how fast you cut and paste).
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
:-)) clients are spreded across 19 access switches. If I could do this using bridge I can move them during working hours
