05-24-2018 07:19 AM - edited 03-05-2019 10:30 AM
Hi community,
My internet provider give me 5 public IP addresses from subnet XX.XX.XX.56 /29
I want to use 5 of them to connect internal servers follow this table:
XX.XX.XX.58 -> IP for Internet gateway
XX.XX.XX.59 -> 192.168.1.19 Port 80
XX.XX.XX.60 -> 192.168.1.20 Port 8080
XX.XX.XX.61 -> 192.168.1.10 Port 21
XX.XX.XX.62 -> 192.168.1.17 Port 8443
Old router (Drytec) use DHCP connection to modem in bridge mode and got 5 aliases, which I could forwarded to internal IP addresses. When I try to setup cisco ASA 5506-X, DHCP doesnt work. What I suppose to do first?
Thank you for help.
05-24-2018 07:25 AM
Just configure your NAT statements on your firewall and it should work fine.
Jon
05-24-2018 07:49 AM
Should I create 1:1 NAT for each address?
05-24-2018 07:50 AM
Up to you really.
You can but you could also just one of the IPs because all the ports are different.
Both should work.
Jon
05-24-2018 08:00 AM
05-24-2018 08:04 AM
When you configure NAT the ASA becomes responsible for that IP so as long as your ISP does the right thing so should your firewall.
Jon
