03-18-2013 04:40 PM - edited 03-04-2019 07:20 PM
ASA 5505 Sec plus lic w/OS 9.1
I want to setup a quick and simple VPN server on my ASA. I want to do local authentication and, once authenticated, I want to allow all internal access. I only have 1 WAN IP. I'm finding a ton of conflicting info online. The ASA is already setup and is operational. I just need the correct commands to setup the VPN. Any help is appreciated.
TIA!
Solved! Go to Solution.
03-25-2013 06:06 PM
I am not sure with you question. Hope it will help you if you just need easy VPN client configuration
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 10 set transform-set ESP-3DES-SHA
crypto dynamic-map Outside_dyn_map 10 set security-association lifetime seconds 28800
crypto dynamic-map Outside_dyn_map 10 set security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 10 set reverse-route
crypto map VPN_MAP 65535 ipsec-isakmp dynamic Outside_dyn_map
crypto map VPN_MAP interface outside
crypto isakmp enable outside
crypto isakmp identity address
group-policy RemoteVPN_local internal
group-policy RemoteVPN_local attributes
dns-server value ---------------------- DNS ip address
split-tunnel-policy tunnelspecified
split-tunnel-network-list value RemoteVPN_splitTunnelAcl <-----access list
default-domain value -------------------DNS server name
tunnel-group RemoteVPN_local type remote-access
tunnel-group RemoteVPN_local general-attributes
address-pool RemoteVPN_local <---DHCP pool
authorization-server-group LOCAL
default-group-policy RemoteVPN_local
tunnel-group RemoteVPN_local ipsec-attributes
pre-shared-key *******
access-list RemoteVPN_splitTunnelAcl standard permit 10.0.0.0 255.0.0.0
aaa authentication http console AD LOCAL
aaa authentication telnet console AD LOCAL
aaa authentication ssh console AD LOCAL
aaa authentication enable console AD LOCAL
ip local pool RemoteVPN_local 10.70.0.129-10.70.0.254 mask 255.255.255.0
and make sure no nat for private traffic and
03-25-2013 05:41 PM
No answer?
I'm probably just missing a simple step...hoping for a nudge in the right direction.
03-25-2013 06:06 PM
03-25-2013 06:12 PM
webvpn
enable outside
svc image disk0:/anyconnect-win-3.1.00495-k9.pkg 1 (download this image from cisco into your flash and give path here)
svc enable
group-policy SSLPolicy internal
group-policy SSLPolicy attributes
dns-server value 10.80.10.16 10.80.10.10
vpn-tunnel-protocol svc webvpn
address-pools value RemoteVPN_local
webvpn
svc keep-installer installed
svc keepalive 15
svc ask none default svc
url-entry enable
tunnel-group DefaultWEBVPNGroup general-attributes
address-pool Web_VPN
authentication-server-group LOCAL
default-group-policy SSLPolicy
Create a local account for user
03-25-2013 06:14 PM
this second config I have pasted for Webvpn anyconnect client..
03-25-2013 07:45 PM
Thanks Tarjeet! Wow! That's a little more complex than I thought.
I actually want to setup a local VPN server on the ASA. I only want to issue a couple of specific IP's for VPN connections. I'll then be connecting from the outside using a Cisco PCF file. I already have a user configured and outside SSH connection configured.
Thx!
03-26-2013 02:36 PM
Hi Alceryes,
You do not need to enable SSH on outside interface for VPN. Also if you have spicific public IP address which will access ASA then you can allow them on outside interface and deny rest of traffic for VPN traffic. Normally we allow any outside traffic because client can be connecting fro anywhere which random public ip adresses all the time.
You can use the first config i gave you. let me know if you need any kind of help. you can search on cisco for remote VPN configuration.
