5600 ASA: Simple gateway failed with 2 subnets with "inside" interface
I have 2 networks 192.168.1.0/24 and 192.168.100.0/24 connected to the inside global interface BVI1
  • IP from 192.168.100.0/24 ping the ASA [OK]
  • The ASA ping any IP in any network  [OK]
  • Any IP from 192.168.1.0/24 is unable to ping any IP to 192.168.100.0/24 and vis-versa
Seems ASA did not want to forward packets between different network !!!
I just want the ASA be a simple gateway for any network connect to inside interface ???
Googled many posts, no solution was found for a simple need.
Can anybody help me ?
Here the config
Result of the command: "show config"
: Saved
: Hardware:   ASA5506, 4096 MB RAM, CPU Atom C2000 series 1250 MHz, 1 CPU (4 cores)
: Written by dtouzeau at 12:55:23.044 UTC Sat Feb 22 2020
ASA Version 9.8(2)
hostname router
names
interface GigabitEthernet1/1
 nameif outside
 security-level 0
 ip address 10.10.1.2 255.255.255.0
interface GigabitEthernet1/2
 bridge-group 1
 nameif CABLE_BLANC
 security-level 100
interface GigabitEthernet1/3
 bridge-group 1
 nameif inside_2
 security-level 100
interface GigabitEthernet1/4
 bridge-group 1
 nameif inside_3
 security-level 100
interface GigabitEthernet1/5
 bridge-group 1
 nameif inside_4
 security-level 100
interface GigabitEthernet1/6
 bridge-group 1
 nameif inside_5
 security-level 100
interface GigabitEthernet1/7
 bridge-group 1
 nameif inside_6
 security-level 100
interface GigabitEthernet1/8
 description Vers FreeWifi
 nameif FREE
 security-level 100
 ip address 192.168.30.75 255.255.255.0
interface Management1/1
 management-only
 no nameif
 no security-level
 no ip address
interface BVI1
 nameif inside
 security-level 100
 ipv6 nd managed-config-flag
 ipv6 nd other-config-flag
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any1
 subnet 0.0.0.0 0.0.0.0
object network obj_any2
object network obj_any3
object network obj_any4
object network obj_any5
object network obj_any6
object network obj_any7
object network LocalNetwork
 subnet 192.168.0.0 255.255.0.0
object network LAN
 description MAISON Network
object network googleDN1
 host 8.8.8.8
object network RESEAU_100
 subnet 192.168.100.0 255.255.255.0
access-list outside_access_in extended permit ip any any4
access-list outside_access_in extended permit ip interface outside any log disable
access-list inside_access_in extended permit ip any any log disable
pager lines 24
logging asdm informational
mtu outside 1500
mtu CABLE_BLANC 1500
mtu inside_2 1500
mtu inside_3 1500
mtu inside_4 1500
mtu inside_5 1500
mtu inside_6 1500
mtu FREE 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
nat (any,FREE) source dynamic any interface
object network LAN
 nat (any,outside) dynamic interface
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 10.10.1.254 1
route inside 192.168.100.0 255.255.255.0 192.168.1.55 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
aaa authentication login-history
http server enable
http 192.168.1.0 255.255.255.0 CABLE_BLANC
http 192.168.1.0 255.255.255.0 inside_2
http 192.168.1.0 255.255.255.0 inside_3
http 192.168.1.0 255.255.255.0 inside_4
http 192.168.1.0 255.255.255.0 inside_5
http 192.168.1.0 255.255.255.0 inside_6
no snmp-server location
no snmp-server contact
service sw-reset-button
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint _SmartCallHome_ServerCA
 no validation-usage
 crl configure
crypto ca trustpool policy
crypto ca certificate chain _SmartCallHome_ServerCA
 certificate ca 513fb9743870b73440418d30930699ff
    30820538 30820420 a0030201 02021051 3fb97438 70b73440 418d3093 0699ff30
    0d06092a 864886f7 0d01010b 05003081 ca310b30 09060355 04061302 55533117
    30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
    13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
    0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
    20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
    65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
    65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d31
    33313033 31303030 3030305a 170d3233 31303330 32333539 35395a30 7e310b30
    09060355 04061302 5553311d 301b0603 55040a13 1453796d 616e7465 6320436f
    72706f72 6174696f 6e311f30 1d060355 040b1316 53796d61 6e746563 20547275
    7374204e 6574776f 726b312f 302d0603 55040313 2653796d 616e7465 6320436c
    61737320 33205365 63757265 20536572 76657220 4341202d 20473430 82012230
    0d06092a 864886f7 0d010101 05000382 010f0030 82010a02 82010100 b2d805ca
    1c742db5 175639c5 4a520996 e84bd80c f1689f9a 422862c3 a530537e 5511825b
    037a0d2f e17904c9 b4967719 81019459 f9bcf77a 9927822d b783dd5a 277fb203
    7a9c5325 e9481f46 4fc89d29 f8be7956 f6f7fdd9 3a68da8b 4b823341 12c3c83c
    ccd6967a 84211a22 04032717 8b1c6861 930f0e51 80331db4 b5ceeb7e d062acee
    b37b0174 ef6935eb cad53da9 ee9798ca 8daa440e 25994a15 96a4ce6d 02541f2a
    6a26e206 3a6348ac b44cd175 9350ff13 2fd6dae1 c618f59f c9255df3 003ade26
    4db42909 cd0f3d23 6f164a81 16fbf283 10c3b8d6 d855323d f1bd0fbd 8c52954a
    16977a52 2163752f 16f9c466 bef5b509 d8ff2700 cd447c6f 4b3fb0f7 02030100
    01a38201 63308201 5f301206 03551d13 0101ff04 08300601 01ff0201 00303006
    03551d1f 04293027 3025a023 a021861f 68747470 3a2f2f73 312e7379 6d63622e
    636f6d2f 70636133 2d67352e 63726c30 0e060355 1d0f0101 ff040403 02010630
    2f06082b 06010505 07010104 23302130 1f06082b 06010505 07300186 13687474
    703a2f2f 73322e73 796d6362 2e636f6d 306b0603 551d2004 64306230 60060a60
    86480186 f8450107 36305230 2606082b 06010505 07020116 1a687474 703a2f2f
    7777772e 73796d61 7574682e 636f6d2f 63707330 2806082b 06010505 07020230
    1c1a1a68 7474703a 2f2f7777 772e7379 6d617574 682e636f 6d2f7270 61302906
    03551d11 04223020 a41e301c 311a3018 06035504 03131153 796d616e 74656350
    4b492d31 2d353334 301d0603 551d0e04 1604145f 60cf6190 55df8443 148a602a
    b2f57af4 4318ef30 1f060355 1d230418 30168014 7fd365a7 c2ddecbb f03009f3
    4339fa02 af333133 300d0609 2a864886 f70d0101 0b050003 82010100 5e945649
    dd8e2d65 f5c13651 b603e3da 9e7319f2 1f59ab58 7e6c2605 2cfa81d7 5c231722
    2c3793f7 86ec85e6 b0a3fd1f e232a845 6fe1d9fb b9afd270 a0324265 bf84fe16
    2a8f3fc5 a6d6a393 7d43e974 21913528 f463e92e edf7f55c 7f4b9ab5 20e90abd
    e045100c 14949a5d a5e34b91 e8249b46 4065f422 72cd99f8 8811f5f3 7fe63382
    e6a8c57e fed008e2 25580871 68e6cda2 e614de4e 52242dfd e5791353 e75e2f2d
    4d1b6d40 15522bf7 87897812 816ed94d aa2d78d4 c22c3d08 5f87919e 1f0eb0de
    30526486 89aa9d66 9c0e760c 80f274d8 2af8b83a ced7d60f 11be6bab 14f5bd41
    a0226389 f1ba0f6f 2963662d 3fac8c72 c5fbc7e4 d40ff23b 4f8c29c7
  quit
telnet 192.168.1.0 255.255.255.0 CABLE_BLANC
telnet timeout 5
ssh stricthostkeycheck
ssh 192.168.1.0 255.255.255.0 CABLE_BLANC
ssh 192.168.1.0 255.255.255.0 inside_2
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.150-192.168.1.254 inside
dhcpd dns 192.168.1.118 192.168.1.101 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
dynamic-access-policy-record DfltAccessPolicy
class-map inspection_default
 match default-inspection-traffic
policy-map global_policy
 class inspection_default
  inspect icmp
  inspect ctiqbe
  inspect dcerpc
  inspect dns
  inspect esmtp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect http
  inspect icmp error
  inspect ils
  inspect ip-options
  inspect ipsec-pass-thru
  inspect lisp
  inspect mgcp
  inspect netbios
  inspect pptp
  inspect rsh
  inspect rtsp
  inspect sip
  inspect skinny
  inspect snmp
  inspect sqlnet
  inspect stun
  inspect sunrpc
  inspect tftp
  inspect vxlan
  inspect waas
  inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:68819168f0a727a74e30b5baa056a36e
Richard Burts
There are several things in the config that I wonder about, such as the access list applied to the inside interface showing as disable. But I believe that the main issue is probably that your ASA route for 192.168.100.0 has 192.168.1.55 as its next hop. Your diagram identifies this as some type of firewall. I would check that device for a security policy that does not permit traffic between the networks.
Rick
post the output of:
sudo iptables -L -v
from the iptables firewall...
