6500 - IOS Upgrade
saquib.tandel
6506 is running CAT OS and I need to upgrade the software to IOS. On CAT OS the switching module and routing module are on different session.
My question
(1) After upgrade wil I get single session to manage switching & routing module
(2) on CATOS we got LACP configured ; is any modification needed on it
(3) Any Change in configuration is needed for Two SUP
Anything else to watch out before the upgrade.
ST
Giuseppe Larosa
Hello Saquib,
you need to follow the procedure for CatOS to IOS conversion
you need to do it two times one for each supervisor /MSFC
so your first step is to remove one sup convert  the remaining sup, then you will remove the converted supervisor and you will insert the other one alone and you will perform conversion again for the second supervisor.
At the end you will insert first sup again and you should be able to get one active and the other standby in native mode
at the end you will get a single session to access the device
LACP is supported on IOS too but you need to configure it. By the way the device needs to be configured.
There is a config conversion tool but it is not recommended.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml
follow the document step by step depending on your sup model
HW and SW requirements are listed
it will take some time (hours)
Hope to help
Giuseppe
Giuseppe Larosa
Hello Saquib,
Hope to help
Giuseppe
Giuseppe Thanks
You are alwayz a great help :-)
I will follow as you recommended.
Ganesh thanks as well.
Ganesh Hariharan
My question
ST
Hi ST,
Check out the below link hope it help !!
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a0080816fbc.shtml
Ganesh.H
