7204 cannot find its config
Tod Larson
Level 3
Level 3
Four times in the past few months we've had a 7204vxr npe-g2 go down since it was unable to read the compact flash card. This usually happens after we reboot the unit due to a site power outage. Upon the reboot it is as if the router can't find its startup configuration. Part of the observable is that we can't do a show disk. It seems if we reseat the cf card then it recovers fine. We are running 12.4 code.
I would appreciate any insight about what is going on. Thank you.
Reza Sharifi
You may have some bad sectors on your CF.  Try formatting it or just replace it and test again.
Sorry, I see that I wasn't clear. It's happened on 4 different 7204 npeg2 routers at 4 different sites.
