7204 VXR loading issue
S.ashok S
We have 7204 roter in our network and one bad day it has strarted giving problem. The problem is restrating continuesouly.
I have collected the console output and kindly find the same as below.
###### [OK]
GigabitEthernet0/2 added as member-1 to port-channel1
GigabitEthernet0/2 taken out of port-channel1
Self decompressing the image : ################################################################################################################################################################################################### [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) 7200 Software (C7200-IS-M), Version 12.3(6f), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 16-Aug-05 21:42 by ssearch
Image text-base: 0x60008AF4, data-base: 0x61C5C000
cisco 7204VXR (NPE-G1) processor (revision B) with 229376K/32768K bytes of memory.
Processor board ID 35480584
SB-1 CPU at 700MHz, Implementation 1, Rev 0.2, 512KB L2 Cache
4 slot VXR midplane, Version 2.11
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
PCI bus mb1 has 0 bandwidth points
PCI bus mb2 has 0 bandwidth points
3 Gigabit Ethernet/IEEE 802.3 interface(s)
509K bytes of non-volatile configuration memory.
62720K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Press RETURN to get started!
*Nov  8 01:05:42.151: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Nov  8 01:05:42.151: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to up
*Nov  8 01:05:42.151: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed state to up
*Nov  8 01:05:43.375: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Nov  8 01:05:43.375: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to up
*Nov  8 01:05:43.375: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to up
*Nov  8 01:05:43.443: %SYS-5-CONFIG_I: Configured from memory by console
*Nov  8 01:05:44.087: %SYS-5-RESTART: System restarted --
*Nov  8 01:05:44.087: %SNMP-5-COLDSTART: SNMP agent on host Shelter5 is undergoing a cold start
*Nov  8 01:05:45.375: %LINK-5-CHANGED: Interface GigabitEthernet0/3, changed state to administratively down
*Nov  8 01:05:46.375: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to up
*Nov  8 01:05:46.375: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to down
*Nov  8 01:05:49.295: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Nov  8 01:05:49.523: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to downGigabitEthernet0/2 taken out of port-channel1
*Nov  8 01:05:55.231: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to down
Buffered messages:
Queued messages:
*Nov  8 01:06:26.163: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Nov  8 01:06:24.363: %ENVM-0-SHUT: Environmental Monitor initiated shutdown
Could any body help me to find the problem.
Thanks in advance.
Thanks and regards,
Ashok Kumar S.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Perhaps failed fan(s).
