05-18-2007 04:36 AM - edited 03-03-2019 05:02 PM
Hi All,
Can someone please confirm the difference between Slot0: and Disk0: on a 7206 router.
I've always understood Slot0: to be the usual PCMCIA flash card that you can plug and unplug from the router. However, I am not certain what Disk0: is then? Is it a physical hard disk inside the Cisco 7206 router?
Andrew
05-18-2007 04:54 AM
Linear memory cards are addressed as the slot0: and slot1: devices. Flash Disk cards are inserted into the slot0 and slot1 physical slots but are addressed as the disk0: and disk1: devices.
Hope this helps
Martin
05-18-2007 05:10 AM
Thanks Martin,
Does this also hold true then on the Cat 6509's?
Andrew
05-18-2007 05:15 AM
Hi Andrew
I believe that with 6500's it is a little different.
On Sup1 and Sup2 the card slot is called slot0:
On Sup720 the card slot is called disk0: or disk1:
Martin
05-18-2007 05:44 AM
Thanks Martin :)
Andrew Morris
05-18-2007 06:23 AM
Ei, just wanna follow up to the question. What is a linear memory card? So where does the PCMCIA fit? disk0 or slot0? Thanks.
