7206vxr...How can I load IOS image in bootflash: and router goes to rommon mode...
arun.stha
rommon 43 > dir bootflash:
  File size           Checksum   File name
   7926772 bytes (0x78f3f4)   0xd9c0d081    c7200p-kboot-mz.124-4.XD5.bin (deleted)
  34463652 bytes (0x20ddfa4)  0xe1b01458    c7200p-spservicesk9-mz.150-1.M4.bin (deleted)
rommon 44 > dir disk2:
Directory of disk2:
2      34463652  -rw-     c7200p-spservicesk9-mz.150-1.M4.bin
8416    7926772   -rw-     c7200p-kboot-mz.124-4.XD5.bin
rommon 45 > dir slot2:
Directory of slot2:
rommon 46 > boot disk2:c7200p-spservicesk9-mz.150-1.M4.bin
boot: cannot find an executable image for this platform on device "bootflash:"
I have two IOS image in disk2 but I am not able to load it in bootflash and getting above error and router goes to romman mode.....
Can any one help me to boot the router normally??????
15 Replies 15
Hi Arun,
Just eject the disk2: and reinsert after removing any dust on the disk and try on next time if face this issue but believe me the best option is to always try with internal bootflash\supboot for 72xx,76xx,65xx chasis.
I had also seen  that bootflash images are deleted but it doesn't allow to copy new image as space is still being used by the deleted image.
To remove all the deleted file from bootflash  use squeeze bootflash. This will free up the space and remove the deleted file.
