7500 Slave RSP high CPU utilization problem
net4net
hello guyes
I have a problem about C-7513 Slave RSP high CPU utilization
I've configured for redundancy RSP configuration(SSO, RPR+ )
Router operated correctly.
But I can find HIgh CPU utiliztion on slave RSP(Standby) by 'IPC Slave CBus Process'
Active RSP CPU utilization is normal(0%).
So I want to fix this problem. but i can't find any solution.
somebody help me.
here is what i tried
1) changied IOS version,
- current IOS Version is RSP-K91PV-M Version 12.2(25)S15,
and I tried 12.4.23 (SP/VIP), 12.3.26(SP/VIP)
2) changeed redundancy mode
- RPR+, SSO(SSO mode supports only 12.2(25)S15 release
current RPR+ mode.
3) swaped RSP module
- swaped slot 6 with slot 7 (both are RSP 8)
here is slave RSP output.
#sh proc cp so
CPU utilization for five seconds: 96%/0%; one minute: 95%; five minutes: 95%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
41 5543432 62852623 88 96.39% 95.67% 95.75% 0 IPC Slave CBus p
6 3548 684 5187 0.31% 0.06% 0.05% 0 Check heaps
1 0 5 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 0 1160 0 0.00% 0.00% 0.00% 0 Load Meter
3 168 306 549 0.00% 0.03% 0.00% 0 Exec
4 0 26 0 0.00% 0.00% 0.00% 0 Retransmission o
5 4 44 90 0.00% 0.00% 0.00% 0 IPC ISSU Receive
7 0 1 0 0.00% 0.00% 0.00% 0 Pool Manager
8 0 2 0 0.00% 0.00% 0.00% 0 Timers
9 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
10 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
11 0 5807 0 0.00% 0.00% 0.00% 0 OIR Handler
12 0 1139 0 0.00% 0.00% 0.00% 0 ALARM_TRIGGER_SC
13 0 97 0 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
#sh redundancy
Redundant System Information :
Available system uptime = 1 hour, 41 minutes
Switchovers system experienced = 0
Hardware Mode = Duplex
Configured Redundancy Mode = rpr-plus
Operating Redundancy Mode = rpr-plus
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Standby Location = slot 7
Current Software state = STANDBY COLD-CONFIG
Uptime in current state = 1 hour, 36 minutes
Image Version = Cisco IOS Software, RSP Software (RSP-K91PV-M), Version 12.2(25)S15, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 07-Dec-07 21:16 by tinhuang
BOOT = slot0:rsp-k91pv-mz.122-25.S15.bin,12;
CONFIG_FILE =
BOOTLDR = bootflash:rsp-boot-mz.124-23.bin
Configuration register = 0x102
Peer (slot: 6, state: ACTIVE) information is not available because this is the standby processor
Giuseppe Larosa
Hello ChangShik,
first of all verify that you have only VIP linecards in the chassis and no old cpuless Interface processors
see
RPR+ operates only in a system with VIPs as the line cards. Systems with legacy IPs default to RPR mode. Up to two legacy IPs can be supported by RPR+ if the service single-slot-reload-enable command is configured.
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t7/feature/guide/gt_rpr2.html#wp1057189
Legacy IPs default to RPR. To allow RPR+ for VIPs when up to two legacy IPs exist in the router, you must configure the service single-slot-reload-enable command. If you do not enable the service single-slot-reload-enable command or if you have more than two legacy IPs, all the line cards are reloaded.
Hope to help
Giuseppe
