08-22-2005 04:52 AM - edited 03-03-2019 10:19 AM
Dear all,
My 7513 suffered from the following problem (snapshoot taken from sh logging) and afterwards all the VIPs restarted, is it a memory problem or what ???
Aug 21 17:06:40: %RSP-3-ERROR: MD error 0000008000004000
-Traceback= 403E55C4 403E5CA8 403E5DD8 403E73DC 403AF588
Aug 21 17:06:40: %RSP-3-ERROR: SRAM parity error (bytes 0:7) 10
-Traceback= 403E5698 403E5CA8 403E5DD8 403E73DC 403AF588
Thanks in advance.
08-22-2005 07:00 AM
Please have a look at the Recommended Actions section of the following document:
Perhaps you could open a case if you are not satisfied with the above approach.
Those issues are normally not easily (if ever) resolved. It might even be "cosmic radiation" to blame:
Many people enjoy reading that, when it's not their router spontaneously crashing!
08-22-2005 07:21 PM
These issues have been around since day dot, and were fixed with the introduction of ECC memory into RSPs and VIPs.
A basic precis of the link is:
1) If it happens once or rarely, it's a single bit
parity error, and should just be dealth with as
a reload with no probably failure on the RSP/
VIP.
2) If it continually occurs, replace the memory on
the affected card. If it continues to happen
replace the affected line card.
Opening a TAC case on PMPE will not get you far really, unless you have the part under contract. Then ask for a replacement after following the troubleshooting procedures.
A card failure would probably present as a cbus stall.
Hope that helps,
-colin.
08-23-2005 12:27 AM
Hi Colin,
Thanks for your reply i think if it happens again, i'll replace the memory on the RSP.
Thanks very much.
