7600 load balancing
p.diaz
Hi.
If I have CEF enabled on a 7600 routers, its possible to load balance by paquet? how can I acomplish that balance?
Tks
cisco_lad2004
Level 5
Level 5
RTR1(config-if)#ip load-sharing ?
per-destination Deterministic distribution
I think it depends on SUP. I am using SUP720 3BXL where per destination only is supported.
Sam
cisco_lad2004
Level 5
Level 5
Below command will give you a clear confirmation:
RTR1#show cef state (add capabilities in some platforms)
Sam
Thanks Sam
No problems Pedro, glad I could help and learn in the process.
Please remember to rate or tick the solved box so other readers can save time when searching through.
Sam
