802.1x not working. PC can't get IP Address from DHCP
19028690
I am trying to get my AAA Server working with a DHCP Server on the same VLAN2 configured and assigned to a Layer 3 Multilayer Switch ports (g1/0/1-2) respectively. 3 Different Layer 2 switch are connected to the Layer 3 Multilayer Switch.
The layer 3 switch is configured with 5 VLAN, VLAN 123 (Engineering), VLAN 124 (Finance), VLAN 125 (HR), VLAN 2 (DHCP+AAA-Server) and VLAN99 (TRUNK NATIVE VLAN to the Layer 2 switch)
Routing
I managed to configure the DHCP server and host connected to Layer 2 switch on thier levels are able to receive their correct IP address from the DHCP server. I have issued to ip helper-address on the vlans so that they are able to receive DHCP message only from the DHCP Server.
I have included a packet tracer file which I have done.I can neither ping the PC or Multilayer Switch from the Level Switch (Switch0-2)
Martin L
I don't know if you got it working but what we missed was check in box on AAA Radius EAP server plus small adjustments like IP of interface vlan 2 on Switch0 so that it can ping both servers. changed hostname Switch0 to SW1 and added Sw1 authentication info in AAA.  see attached files
Regards, ML
**Please Rate All Helpful Responses **
11 Replies 11
Martin L
Looks good; couple things:  L2 switches should have manually assigned IPs for management access purpose from reserved IT Vlan subnet.  Your L2 switches have the same IP of 192.168.0.1, all 3, for interface vlan 1.  Of course, There should be no 2 devices with same IP on network anywhere inside the company.
Also, L3 sw does not have interface vlan1 up nor has IP assigned.  Assuming that your IT department is on vlan 1 and in 192.168.0.1/24, once u add /change IPs , switches will be able to ping.
Using vlan 1 is not good idea for security; so u may want to change IT dept vlan to vlan 99.
Normally Regular PCs should not be able to ping L2/L3 switches anyway; such PC should be only designated IT PC to admin and mange switches/routers.
Regards, ML
Do check the attachment
I have updated accordingly the Native VLAN now is VLAN99 on Switch0 and MLS. I have also set the SVI interface for VLAN 99 ip address to 192.168.99.11 at Switch0 and 192.168.99.1 the at MLS.
I am still not sure why I am unable to reach the other VLAN interface IP addresses or the PCs when I ping HR1 PC, DHCP and AAA server.
show run on Switch0
Building configuration...
Current configuration : 1822 bytes
version 15.0
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
aaa new-model
aaa authentication dot1x default group radius
dot1x system-auth-control
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 125
switchport mode access
authentication port-control auto
dot1x pae authenticator
interface FastEthernet0/2
switchport access vlan 124
interface FastEthernet0/3
switchport access vlan 123
interface FastEthernet0/4
shutdown
interface FastEthernet0/5
shutdown
interface FastEthernet0/6
shutdown
interface FastEthernet0/7
shutdown
interface FastEthernet0/8
shutdown
interface FastEthernet0/9
shutdown
interface FastEthernet0/10
shutdown
interface FastEthernet0/11
shutdown
interface FastEthernet0/12
shutdown
interface FastEthernet0/13
shutdown
interface FastEthernet0/14
shutdown
interface FastEthernet0/15
shutdown
interface FastEthernet0/16
shutdown
interface FastEthernet0/17
shutdown
interface FastEthernet0/18
shutdown
interface FastEthernet0/19
shutdown
interface FastEthernet0/20
shutdown
interface FastEthernet0/21
shutdown
interface FastEthernet0/22
shutdown
interface FastEthernet0/23
shutdown
interface FastEthernet0/24
shutdown
interface GigabitEthernet0/1
switchport trunk native vlan 99
switchport mode trunk
interface GigabitEthernet0/2
shutdown
interface Vlan1
ip address 192.168.0.1 255.255.255.0
interface Vlan99
mac-address 000c.855d.7b01
ip address 192.168.99.11 255.255.255.0
radius-server host 192.168.2.12 auth-port 1645 key cisco
line con 0
login
line vty 0 4
line vty 5 15
end
show run on MLS
Current configuration : 2624 bytes
version 16.3.2
hostname Switch
no ip cef
ip routing
no ipv6 cef
interface GigabitEthernet1/0/1
switchport access vlan 2
switchport nonegotiate
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
shutdown
interface GigabitEthernet1/0/8
shutdown
interface GigabitEthernet1/0/9
shutdown
interface GigabitEthernet1/0/10
shutdown
interface GigabitEthernet1/0/11
shutdown
interface GigabitEthernet1/0/12
shutdown
interface GigabitEthernet1/0/13
shutdown
interface GigabitEthernet1/0/14
shutdown
interface GigabitEthernet1/0/15
shutdown
interface GigabitEthernet1/0/16
shutdown
interface GigabitEthernet1/0/17
shutdown
interface GigabitEthernet1/0/18
shutdown
interface GigabitEthernet1/0/19
shutdown
interface GigabitEthernet1/0/20
shutdown
interface GigabitEthernet1/0/21
shutdown
interface GigabitEthernet1/0/22
shutdown
interface GigabitEthernet1/0/23
shutdown
interface GigabitEthernet1/0/24
shutdown
interface GigabitEthernet1/1/1
shutdown
interface GigabitEthernet1/1/2
shutdown
interface GigabitEthernet1/1/3
shutdown
interface GigabitEthernet1/1/4
shutdown
interface Vlan1
no ip address
interface Vlan2
mac-address 00d0.ba75.ec01
ip address 192.168.2.1 255.255.255.0
interface Vlan99
mac-address 00d0.ba75.ec05
ip address 192.168.99.1 255.255.255.0
interface Vlan123
mac-address 00d0.ba75.ec02
ip address 192.168.123.1 255.255.255.0
ip helper-address 192.168.2.11
ip helper-address 192.168.2.12
interface Vlan124
mac-address 00d0.ba75.ec03
ip address 192.168.124.1 255.255.255.0
interface Vlan125
mac-address 00d0.ba75.ec04
ip address 192.168.125.1 255.255.255.0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
not sure what you are tying to do and whether is possible in PT; Port-based AAA authentication for PCs?
as far as I know PT can do console and telnet access via AAA.
I take a look later.
Hi what I am trying to do is be able to get a IP address from the DHCP Server but my lab work requires to implement the AAA Server for authentication purposes for the PC to get an IP from the DHCP server.
I currently have layer 2 switch doing native trunking on vlan 99 to the layer 3 switch is that okay? should I not use the vlan that I used to do native trunking for the IT department remote management? I can't seem to get 802.1x working on the access switch.
I have opened your file. Which IP address can you not ping from which IP address ?
Source IP --> Destination IP
I'm not clear what you are trying to say? I am using VLANs here. I can't ping the Layer 3 Switch, Servers and PCs from the Layer 2 Switch. Also I cannot ping Layer 2 Switch from the Servers, Layer 3 switch and the host devices. I have re-did my packet tracer file again. Perhaps you might want to take a look.
all 3 L2 switches have exactly same IP address on vlan 1; they should have unique; L2 usually have 1 SVI up; not both vlan 1 and vlan 99. PT bug here; I would use vlan 99 but vlan 1 is ok.
L2 switches are missing ip default-gateway 192.168.x.x (vlan 99 or int vlan 1 of L3)
L3 sw does not have IP on vlan 1.
once you fix those issues above, you get pings ok.
The issue is 802.1x for PCs, which I am not sure works in PT but I check. Pcs are getting IPs without authentication 802.1x but not with 802.1x
Hi Martin,
Yes I set an IP address on the respective Department vlan interface of Layer 2 Switches  and managed to ping them to the PCs, DHCP Server and AAA server IP address but 802.1x indeed is still not working which is quite odd.
I set 802.1x authentication for PC access ports only and not the trunk links but not sure why The PC are unable to get their IP addresses from the DHCP server like you said.
From my understanding we should set 802.1x on ports where PCs are going to be connected and not trunk ports/links which.
How strange that I can get IP address without 802.1x but not with 802.1x
I hope someone can enlighten me on this.
find attached the working config with full end to end reachability.
Martin L
Regards, ML
