06-12-2020 08:01 AM
Hi all,
I have BGP running using a private AS, within the BGP config I also have an ipv4 address family for a separate VRF, within this I have 3 neighbors, 1 is iBGP (my firewall) the other 2 are eBGP links to ISP's. As BGP is running globally using the private AS I am using the local-as command on the ISP neighbors. However 1 of the ISP's is complaining saying they are receiving updates from our private AS?
When I run the show command on my side I can see the local AS is being set correctly.
I believe the ISP is using a Juniper not sure if that could be the issue? Some kind of compatibility?
Thanks in advance
Solved! Go to Solution.
06-12-2020 10:01 AM
To make sure your neighbor does not see the ASN 65000 configured on your router bgp process, you need to use "local-as 10000 no-prepend replace-as".
Please refer to the following configuration guide for more information:
https://www.cisco.com/c/en/us/td/docs/ios/12_2s/feature/guide/fsbgpdas.html
06-12-2020 08:10 AM
Siunce we not have your configuration to validate
so please provide your configuraiton bit, also request provider about the Logs to verify the same.
make sure your bgp update interface set correctly.
06-12-2020 08:17 AM
router bgp 65000
address-family ipv4 vrf Outside
bgp router-id 5.5.5.6
network 5.5.5.0 mask 255.255.255.0
redistribute static
neighbor 1.1.1.1 remote-as 100
neighbor 1.1.1.1 local-as 10000
neighbor 1.1.1.1 description ISP1
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 prefix-list OutsideOut out
neighbor 2.2.2.2 remote-as 200
neighbor 2.2.2.2 local-as 10000
neighbor 2.2.2.2 description ISP2
neighbor 2.2.2.2 activate
neighbor 2.2.2.2 weight 10
neighbor 2.2.2.2 prefix-list OutsideOut out
neighbor 5.5.5.5 remote-as 10000
neighbor 5.5.5.5 local-as 10000
neighbor 5.5.5.5 description To firewall
neighbor 5.5.5.5 activate
exit-address-family
Obviously I have changed the IP's and AS's.
What logs should I ask for?
06-12-2020 08:30 AM
what updates they seeing "ISP's is complaining saying they are receiving updates from our private AS?"
06-12-2020 08:37 AM
They basically sent me some output from what looks like a Juniper:
AS path: 10000 65000
So actually that looks like they are receiving my "real" AS (10000) but maybe the trouble is they are also seeing 65000 within the AS path?
If the 'local-as' is applied to a neighbor would it also send the global AS?
06-12-2020 10:01 AM
