8510 100% CPU Utilization due to IP Input
spartain
I am having a problem with a 8510 that is running 12.1(22) the problem is that we can only get it to pass about 4mb if traffic before it chokes and starts dropping packets. I am going to include the sh ip interface and sh int stats. I was noticing that all the packets are process switched. I cannot enable IP Fast Switching on the DS3 interfaces. Dont know if I should be able to or not. I read that it is ASIC switched so this would make sense...
Any help would be GREATLY appreciated.
ATM1/0/2
Switching path Pkts In Chars In Pkts Out Chars Out
Processor 1042133 55233049 39462393 2091506829
Route cache 0 0 0 0
Total 1042133 55233049 39462393 2091506829
ATM1/0/3
Processor 1927485 102156705 39454111 2091067883
Route cache 0 0 0 0
Total 1927485 102156705 39454111 2091067883
ATM1/1/0
Processor 14187520 751938560 9521193 504623229
Route cache 0 0 0 0
Total 14187520 751938560 9521193 504623229
spartain
After doing some reading I have come across a page here on cisco's site that says with a ARM 1 you only want to use multipoint configured sub interfaces as the point-to-point routes all the traffic by the processor which would drive up the processor utilization. I am pasting the configs of these interfaces below (Subs) in which i am using point-to-point for all of them. I am going to test by configuring one to multipoint to see if this fixes my problem.
interface ATM0.3 point-to-point
ip address 1.2.254.18 255.255.255.252
atm pvc 0 250 pd on encap aal5snap interface ATM1/0/1 1 74
interface ATM0.10 point-to-point
ip address 1.2.254.13 255.255.255.252
atm pvc 0 146 pd on encap aal5snap interface ATM1/1/0 1 73
interface ATM0.30 point-to-point
ip address 1.2.254.38 255.255.255.252
atm pvc 0 150 encap aal5snap interface ATM1/0/2 1 76
interface ATM0.40 point-to-point
ip address 1.2.254.2 255.255.255.252
atm pvc 0 152 pd on encap aal5snap interface ATM1/0/3 1 75
if you guys could look these over to see if anything else stands out that would be great.
Thanks again,
Mike
