867VAE dual WAN SDSL and ADSL failover
I have the 867VAE router, and I'm looking for configuration example to implement the SDSL as the primary WAN and the ADSL for the backup.
Could you send me plz an example of configuration?
Cheer
BR
A.Aziz
5 Replies 5
Amit Goyal
Below configuration should help. Lets assume you have dialer10 (Primary) and dialer20 (backup).
track 10 ip sla 10
ip sla 10
 icmp-echo 8.8.8.8
ip sla schedule 10 life forever start-time now
ip route 8.8.8.8 255.255.255.255 dialer10 permanent
ip route 0.0.0.0 0.0.0.0 dialer10 track 10
ip route 0.0.0.0 0.0.0.0 dialer20 100
-Amit
Hello Amit,
Thank you for your replay.
The configuration seam correct, the only thing those not works is the failover.
In fact,
I unplugged the primary WAN failover does not happen
Tks
>When you unplugged primary ISP, do you see track 10 is going down?
Please provide below output during primary ISP down.
show track 10
show ip route 0.0.0.0
-Amit
Pleas see as bellow :
AIST#sh ip route 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
  Known via "static", distance 253, metric 0 (connected), candidate default path
  Routing Descriptor Blocks:
  * directly connected, via Dialer1
      Route metric is 0, traffic share count is 1
AIST#sh track 1
Track 1
  IP SLA 1 reachability
  Reachability is Down
    3 changes, last change 03:14:29
  Latest operation return code: Timeout
  Tracked by:
    STATIC-IP-ROUTING 0
BR
  * directly connected, via Dialer1 <<<<<<<Secondary ISP
>Default route is pointing to dialer 1 which has AD 253.
>That means configuration and fail-over is working.
>There could be another concern that secondary ISP is really able to pass traffic coming from your end?
>Do a traceroute for any other public ip and check if you see secondary ISP in first hop.
>By default dialer interface remains up all the time. No matter if DSL line is up or not.
>"Show caller ip" will tell you if you are able to see secondary ISP or not.
>May be you need to check with your secondary ISP for this.
-Amit
