877W - Cannot connect using Cisco Configuration Assistant - CCA
bradteeters
Looking to setup a backup router for our disaster recovery plan.  We currently have a Cisco 877W that was setup by our ISP.  I can log into the device with Telnet and a console cable, but I am not good using IOS commands, so I would like to use CCA.  Unfortunatley, I cannot access the router using the software.  I assume something is disabled in the config.  Like HTTP or something.  Can someone help me?
Current Config (passwords and login info removed) ATTACHED
johnlloyd_13
Level 9
Level 9
hi brad,
enable HTTP access by issuing the "ip http server" command. give it a try.
