887-m drops overnight
Benjamin Tincey
Hi All,
I have recently configured a cisco 887-m for a new ADSL connection.
The connection is presented as ethernet from an NTU.
The  first day i put it in, it was working for 2 days then dropped. Turning  the router off and on fixes the issue except twice now it has dropped  again overnight. When i console in i cannot ping google.com from the  router.
Here is the config
ROUTER#sh run
Building configuration...
Current configuration : 2029 bytes
version 12.4
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
no ip source-route
ip cef
ip domain name mydomain.com
ip name-server 203.161.127.1
ip name-server 203.153.224.42
vpdn enable
vpdn-group pppoe
username oiadmin privilege 15 password 7 014357055F065701
archive
log config
hidekeys
ip ssh version 2
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
switchport access vlan 2
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Vlan2
ip address xxx.xxx.xxx.xxx 255.255.255.252
no ip redirects
ip nat outside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 (ISP GATEWAY IP)
no ip http server
no ip http secure-server
ip nat inside source list mydomain-ip interface Vlan2 overload
ip nat inside source static tcp 192.168.0.100 9100 interface Vlan2 9100
ip nat inside source static tcp 192.168.0.11 1433 interface Vlan2 1433
ip nat inside source static tcp 192.168.0.11 21 interface Vlan2 21
ip nat inside source static tcp 192.168.0.5 443 interface Vlan2 443
ip nat inside source static tcp 192.168.0.5 3389 interface Vlan2 3389
ip nat inside source static tcp 192.168.0.5 80 interface Vlan2 80
ip access-list extended mydomain-ip
permit ip 192.168.0.0 0.0.0.255 any
control-plane
banner login ^C
********** Router *********
    • WARNING **
      ** Access to this device is restricted to authorized persons only **
^C
line con 0
password 7 0256555A0F0B5E2F
login
no modem enable
line aux 0
line vty 0 4
login local
transport input telnet ssh
no scheduler max-task-time
end
I don't see any line issues, however, if you say that a reboot fixes it then I'm incline to consider a potential IOS bug.
I can see you are using an IOS "T" train.  I'd recommend you upgrade your IOS "M" train.
7 Replies 7
Leo Laohoo
post the output to the command "sh dsl atm".
The atm interface is not being used as WAN connection. The connection is coming in through F0 which has switchport access to VLAN2
PER-HL-RTR-01#sh dsl int atm0
ATM0
Alcatel 20190 chipset information
Line has not yet been activated.
Modem Status:    Down (DMTDSL_STOP)
DSL Mode:        Unknown
Interrupts:      4124 (0 spurious)
PHY Access Err:  0
Activations:     0
LED Status:      OFF
LED On Time:     500
LED Off Time:    500
Init FW:         init_AMR-3.0.014_no_bist.bin
Operation FW:    AMR-3.0.014.bin
FW Source:       embedded
DSL: Training log buffer capability is not enabled
PER-HL-RTR-01#
Can you post the following output commands:
1.  sh int f0;
2.  sh int dial 0; and
3.  sh version
Router#sh int f0
FastEthernet0 is up, line protocol is up
  Hardware is Fast Ethernet, address is 0026.99c6.721f (bia 0026.99c6.721f)
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 10/255
  Keepalive set (10 sec)
  Half-duplex, 10Mb/s
  Last input never, output never, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 430000 bits/sec, 44 packets/sec
  5 minute output rate 66000 bits/sec, 30 packets/sec
     499701 packets input, 626915803 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     328793 packets output, 61469934 bytes, 0 underruns
     7 output errors, 8248 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
I dont have a dialer interface configured
ROUTER#sh ver
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(15)T10, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 14-Sep-09 23:35 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
PER-HL-RTR-01 uptime is 1 hour, 45 minutes
System image file is "flash:c870-advsecurityk9-mz.124-15.T10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 877-M (MPC8272) processor (revision 0x400) with 118784K/12288K bytes of memory.
Processor board ID FHK135060A5
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
Thanks for your help Leo,
I will update to 151-4.M7 and see how that goes
Make sure your DRAM and your router's flash is the right amount.
