887VA no connection on ADSL2+ (
Greetings,  long time lurker, first time poster :)
We are currently going through the process of replacing our external sites routers from 837's to 887va's.  Unfortunately at a number of sites we are experiencing issues.
I have been looking at one of the sites and have so far managed to get as far as getting a ppp light on but still no connectivity through to the net. Device itself is capable of pinging the DNS servers that are delivered via connection but nothing else.  Please see below Config used to program  device.  I think that the problem is something silly but can't tell what it is.  (I have obscured any identifying/secure information)
Routers and pc's connected to routers are assigned addresses in 192.168.231.xxx range
ICT computers are assigned addresses in 192.168.112.xxx range
Should all be using 256aes encryption but for some reason old router 837 model falls back to 3des, we do not want to replicate that behaviour.
Thanks.
no service slave-log
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime localtime
service password-encryption
no service dhcp
boot-start-marker
boot-end-marker
aqm-register-fnf
logging buffered 16384 informational
enable password *PASSWORD*
no aaa new-model
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 2:00
no ip source-route
no ip domain lookup
ip domain name basildon.gov.uk
ip inspect name IOSFW tcp timeout 3600
ip inspect name IOSFW udp timeout 30
ip inspect name IOSFW ftp timeout 3600
ip inspect name IOSFW h323 timeout 3600
ip inspect name IOSFW http timeout 3600
ip inspect name IOSFW rcmd timeout 3600
ip inspect name IOSFW realaudio timeout 3600
ip inspect name IOSFW smtp timeout 3600
ip inspect name IOSFW sqlnet timeout 3600
ip inspect name IOSFW streamworks timeout 3600
ip inspect name IOSFW tftp timeout 30
ip inspect name IOSFW vdolive timeout 3600
ip cef
no ipv6 cef
username *USER* privilege 15 password *PASSWORD*
controller VDSL 0
ip ssh time-out 20
ip ssh authentication-retries 2
ip ssh logging events
ip ssh version 2
crypto isakmp policy 10
 encr aes 256
 authentication pre-share
 group 5
crypto isakmp key *SECRETKEY* address *Address of interface on ASA*
crypto ipsec transform-set 1 esp-aes 256 esp-sha-hmac
 mode tunnel
crypto map VPN 10 ipsec-isakmp
 set peer *Address of External interface on ASA*
 set transform-set 1
 match address 112
interface ATM0
description ADSL PHYSICAL INTERFACE
no ip address
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0
no ip address
no shutdown
interface FastEthernet0
description CORPORATE ACCESS
switchport access vlan 10
no ip address
no shutdown
interface FastEthernet1
no ip address
no shutdown
interface FastEthernet2
no ip address
no shutdown
interface FastEthernet3
no ip address
no shutdown
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.231.33 255.255.255.248
ip access-group 115 in
interface Dialer1
description ADSL VIRTUAL INTERFACE
ip address negotiated
ip access-group 111 in
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname (Hostname from ISP)
ppp chap password (Password from ISP)
ppp pap sent-username (Hostname from ISP) password (Password from ISP)
ppp ipcp dns request
ppp ipcp wins request
crypto map VPN
hold-queue 224 in
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source route-map NONAT interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
route-map NONAT permit 10
match ip address 114
access-list 1 permit *MD NW Address* 0.0.0.63
access-list 1 permit 192.168.112.0 0.0.0.255
access-list 1 permit 192.168.231.32 0.0.0.7
access-list 111 remark OUTSIDE-IN-ACL
access-list 111 permit icmp *MD NW Address* 0.0.0.63 any echo
access-list 111 permit icmp *MD NW Address* 0.0.0.63 any echo-reply
access-list 111 permit icmp *MD NW Address* 0.0.0.63 any traceroute
access-list 111 permit icmp *Virgin Network Address* 0.0.0.31 any echo
access-list 111 permit icmp *Virgin Network Address* 0.0.0.31 any echo-reply
access-list 111 permit icmp *Virgin Network Address* 0.0.0.31 any traceroute
access-list 111 permit esp *MD NW Address* 0.0.0.63 any
access-list 111 permit udp *MD NW Address* 0.0.0.63 any eq isakmp
access-list 111 permit udp *MD NW Address* 0.0.0.63 any eq 10000
access-list 111 permit tcp *MD NW Address* 0.0.0.63 any eq 22
access-list 111 permit tcp *Virgin Network Address* 0.0.0.31 any eq 22
access-list 111 permit ip 192.168.0.0 0.0.255.255 192.168.231.32 0.0.0.7
access-list 112 remark CORPORATE-SUBNET
access-list 112 permit ip 192.168.231.32 0.0.0.7 any
access-list 114 remark NONAT-LIST
access-list 114 deny   ip 192.168.231.32 0.0.0.7 any
access-list 115 remark CORPORATE-INTERFACE-ACL
access-list 115 permit ip 192.168.231.32 0.0.0.7 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
exec-timeout 60 0
password (ANOTHERPASS)
logging synchronous
login local
no modem enable
stopbits 1
line aux 0
line vty 0 4
exec-timeout 60 0
logging synchronous
login local
transport input ssh
transport output ssh
scheduler allocate 20000 1000
end
I made some changes to your config which I think should get your VPN connected (important parts marked in bold):
no service pad
no service dhcp
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
no ip source-route
no ip domain lookup
ip cef
no ipv6 cef
controller VDSL 0
ip ssh time-out 20
ip ssh version 2
encr aes 256
group 5
mode tunnel
set transform-set 1
match address 112
interface ATM0
no ip address
atm vc-per-vp 64
pvc 0/38
interface Ethernet0
no ip address
no shutdown
no ip address
no shutdown
no ip address
no shutdown
no ip address
no shutdown
no ip address
no shutdown
interface Vlan1
no ip address
shutdown
interface Vlan10
interface Dialer1
encapsulation ppp
dialer pool 1
dialer-group 1
crypto map VPN
hold-queue 224 in
ip http server
access-list 112 remark CRYPTO_TRAFFIC
control-plane
line con 0
exec-timeout 60 0
logging synchronous
login local
no modem enable
stopbits 1
line aux 0
line vty 0 4
exec-timeout 60 0
logging synchronous
login local
transport input ssh
end
7 Replies 7
there is no 'ip nat inside' configured anywhere. Are you getting your Internet through the VPN, or is it supposed to come directly from the DSL connection ?
Internet should come through the VPN,  Is a direct site to site connection.  No connectivity to WWW outside of corporate network.
Thanks.
For some more clarity,  Site to Site Vpn, should use AES256, profile on ASA then configures things like proxy for devices.  They used to be split tunnel VPN but a corporate decision was made to pass everything through to our ASA.
When looking at the ASA I am seeing no attempted communication from the router at all.  As soon as we plug in the old router it all works as normal.
Thanks.
no service pad
no service dhcp
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
no ip source-route
no ip domain lookup
ip cef
no ipv6 cef
controller VDSL 0
ip ssh time-out 20
ip ssh version 2
encr aes 256
group 5
mode tunnel
set transform-set 1
match address 112
interface ATM0
no ip address
atm vc-per-vp 64
pvc 0/38
interface Ethernet0
no ip address
no shutdown
no ip address
no shutdown
no ip address
no shutdown
no ip address
no shutdown
no ip address
no shutdown
interface Vlan1
no ip address
shutdown
interface Vlan10
interface Dialer1
encapsulation ppp
dialer pool 1
dialer-group 1
crypto map VPN
hold-queue 224 in
ip http server
control-plane
line con 0
exec-timeout 60 0
logging synchronous
login local
no modem enable
stopbits 1
line aux 0
line vty 0 4
exec-timeout 60 0
logging synchronous
login local
transport input ssh
end
Thanking thee muchly,
I probably won't get a chance to get that tested now until Monday morning.  I will update the thread with results after that.
Curious to know if it works...have a great weekend.
Well that worked, I don't understand why but it does resolve the vpn connecting issue. Thanks for the assist, Site are a lot happier now their connection isn't dropping all the time.
