891f route to management ip
Got an 891F to use at home.
I have very basic networking knowledge. Never had advanced network products in my hand.
Desired setup at this moment should be:
pppoe connection from internet provider (on GI8)
vlan 2 for main clients wired and wifi: computers, phones, laptops... (3interfaces) 192.168.2.0 (internet access and vlan 4 access). Until I get an proper wifi ap, I will use an old linksys wifi router as wifi access point
vlan3 for smart home clients via wifi 192.168.3.0 (internet acces only, no acces to/from other vlans). Until I will get a proper wifi ap, I will use an old dlink wifi router as ap)
vlan4 for ip cameras (4poe interfaces) 192.168.4.0 (no internet, access from vlan2)
What I have done.
Via serial console  initial basic setup completed
Set management interface on fast ethernet 0 192.168.1.2 (I need gigabit interfaces for wired clients and cameras)
set vlans on interfaces
Got dhcp working.
I need to get management working from vlan2 interfaces. (route?)
Secondary ip for interface fast ethernet 0 didnt work because overlap over vlan2 is not permitted.
After that I would like to set pppoe and internet access over gi8 interface.
A basic firewall setup is needed ? Or this is working by default, like on my tplink router?
Any guideline will be appreciated.
Thank you
Router#sh run
Building configuration...
Current configuration : 2767 bytes
! Last configuration change at 20:15:40 UTC Tue Jan 7 2020
version 15.5
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$9EqU$azp8q1xXw3NIN9Ft3Kp0h1
no aaa new-model
ethernet lmi ce
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp excluded-address 192.168.3.1 192.168.3.10
ip dhcp excluded-address 192.168.4.1 192.168.4.10
ip dhcp pool main-pool
 import all
 network 192.168.2.0 255.255.255.0
 default-router 192.168.2.1
 dns-server 8.8.8.8
ip dhcp pool iot-pool
 import all
 network 192.168.3.0 255.255.255.0
 dns-server 8.8.8.8
ip dhcp pool cameras-pool
 import all
 network 192.168.4.0 255.255.255.0
 dns-server 8.8.8.8
no ip domain lookup
ip domain name local
ip cef
no ipv6 cef
license udi pid C891F-K9 sn FDZ20359149
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface FastEthernet0
 ip address 192.168.1.2 255.255.255.0
 duplex full
 speed auto
interface GigabitEthernet0
 switchport access vlan 4
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 switchport access vlan 3
 no ip address
interface GigabitEthernet4
 switchport access vlan 2
 no ip address
interface GigabitEthernet5
 no ip address
interface GigabitEthernet6
 no ip address
interface GigabitEthernet7
 no ip address
interface GigabitEthernet8
 no ip address
 shutdown
 duplex auto
 speed auto
interface Vlan1
 no ip address
 shutdown
interface Vlan2
 description main
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
interface Vlan3
 description IOT
 ip address 192.168.3.1 255.255.255.0
 ip nat inside
interface Vlan4
 description cameras
 ip address 192.168.4.1 255.255.255.0
 ip nat inside
interface Async3
 no ip address
 encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line 3
 modem InOut
 speed 115200
 flowcontrol hardware
line vty 0 4
 password Cisco
 login
 transport input none
scheduler allocate 20000 1000
end
I have made some additions (marked in bold) to your configuration. You also might need to create Vlan 2, 3, and 4 manually:'
Router#conf t
Router(config)#vlan 2
Router(config)#vlan 3
Router(config)#vlan 4
Router#sh run
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
import all
dns-server 8.8.8.8
import all
dns-server 8.8.8.8
import all
dns-server 8.8.8.8
no ip domain lookup
ip cef
no ipv6 cef
interface BRI0
no ip address
encapsulation hdlc
shutdown
ip nat inside
duplex full
speed auto
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Vlan2
description main
ip nat inside
interface Vlan3
description IOT
ip nat inside
interface Vlan4
description cameras
ip nat inside
interface Async3
no ip address
encapsulation slip
no ip http server
ip nat inside source list 1 interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 dhcp
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 1 permit 192.168.4.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
line vty 0 4
password Cisco
login
end
Thank you for your answer,
I put your lines in config.
Everywhere I put "ip nat inside" , "ip virtual-reassembly in" appeared. I suppose this is normal.
However, I don t have ping nor telnet to 192.168.1.2 which was supposed to be management ip.
It not a must to be bound to fe0 interface. All I need is to be able to manage the router from network without  "wasting" a gigabit interface.
Yet, i did not connect GE8 to internet provider.
I will do that after I will have inside intervlan working.
Thank You
LOL
Found I had to enable telnet to work.
No need to configure FE0, it works on any interface is up ?(eg vlan 2)
