896 router cannot synchronize for 100Mbit
tsipoulanis
Hello everyone,
i live in germany and i have a new Internet 100mbit from M-net Provider.
i have found that i need the 30a Profile thats why i configure the next command on the controller.
controller VDSL 0
 operating mode vdsl2
 firmware filename flash:VA_B_38V_d24m.bin
and the next commands on the ethernet0.40 because of the tagging to the provider.
interface Ethernet0
 no ip address
interface Ethernet0.40
 description DSL Internet Vlan 40tagged
 encapsulation dot1Q 40
 pppoe enable group global
 pppoe-client dial-pool-number 1
because of the PPPoE i have shutdown the ATM.
although the line is all the time down.
Router#show controllers vDSL 0
Controller VDSL 0 is DOWN
Daemon Status:           Establishing Link
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'IFTN'
Chip Vendor Specific:   0x0000                   0xC0C8
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   '    '
Modem Vendor Specific:  0x4602                   0x0000
Modem Vendor Country:   0xB500                   0x0000
Serial Number Near:    FCZ214790BM C896VA-K 15.7(3)M1
Serial Number Far:
Modem Version Near:    15.7(3)M1
Modem Version Far:     0xc0c8
Modem Status:            Unknown
DSL Config Mode:         VDSL2
Trained Mode:
TC Mode:                 UNKNOWN
Selftest Result:         0x00
DELT configuration:      disabled
DELT state:              not running
Full inits:             0
Failed full inits:      0
Short inits:            0
Failed short inits:     19
Firmware        Source          File Name
VDSL            user config     flash:VA_B_38V_d24m.bin
Modem FW  Version:      170321_1253-4.02L.03.B2pvC038v.d24m
Modem PHY Version:      B2pvC038v.d24m
Trellis:                 OFF                      OFF
SRA:                     disabled                disabled
 SRA count:              0                       0
Bit swap:                enabled                 enabled
Training Log :  Stopped
Training Log Filename : flash:vdsllog.bin
Router#
can anyone help me?
best regards,
Thomas
30 Replies 30
use the last configuration I sent. Your current one has many errors, which I changed in the last config I posted. Here it is again:
Current configuration : 8600 bytes
version 15.7
hostname h2h
boot-start-marker
boot system flash c800-universalk9-mz.SPA.157-3.M.bin
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login local_access local
aaa session-id common
clock timezone GMT 1 0
ip dhcp excluded-address 10.10.10.1
ip dhcp pool cvo-pool
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
lease 0 2
no ip domain lookup
ip domain name
ip cef
cts logging verbose
license udi pid C897VA-K9 sn FCZ2147E3DW
username cisco privilege 15 secret 5 aaaaaaaaaaaaa
redundancy
track 1 ip sla 1 reachability
ip local policy route-map SLA_ICMP
controller VDSL 0
operating mode auto
firmware filename flash:VA_A_39t_B_38r1_24o_rc1_SDK_4.14L.04A.bin
no cdp run
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
cdp enable
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface Ethernet0
no ip address
interface Ethernet0.7
description Primary VDSL Internet Verbindung O2 - VLAN 7 tagged
encapsulation dot1Q 7
interface GigabitEthernet0
no ip address
spanning-tree portfast
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
description Backup Link To Fritz!Box
ip address dhcp
duplex auto
speed auto
interface Vlan1
description LAN
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1412
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname yourhost@yourlogindomain
ppp chap password yourpassword
ppp pap sent-username yourusername
ppp ipcp dns request
ppp ipcp mask request
no cdp enable
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source route-map WAN_PRIMARY interface Dialer1 overload
ip nat inside source route-map WAN_BACKUP interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 dhcp 10
ip sla 1
icmp-echo 8.8.8.8 source-interface Dialer1
frequency 10
ip sla schedule 1 life forever start-time now
access-list 100 permit ip 10.10.10.0 0.0.0.255 any
access-list 101 permit icmp any host 8.8.8.8
route-map WAN_PRIMARY permit 10
match ip address 100
match interface Dialer1
match interface GigabitEthernet8
route-map SLA_ICMP permit 10
match ip address 101
set interface Dialer1
ip ssh time-out 60
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
dialer-list 1 protocol ip permit
event manager applet CLEAR_NAT
event track 1 state down
event syslog pattern “TRACKING-5-STATE”
action 1 cli command “enable”
action 2 cli command “clear ip nat translation forced”
action 3 cli command “exit”
event track 1 stateup
