A few questions about BGP output and commands
hfakoor222
1)Is that the address in Hex below?     Also what does Refcount mean?
The following list explains some of the fields that appear in the preceding output from the
show ip bgp paths
command.
  • Address— Memory address of where the path is stored.
  • Hash— Hash bucket where the path is stored.
  • Refcount— Number of prefixes using that path.
  • Metric— Multi-exit ...
6 Replies 6
show ip bgp paths
command.
How can I interpret or translate that memory hash in where it's stored to something I can understand?
Or how can I make use of it?
good question. The only thing I could find that might explain the concept of the hash buckets is the thread below. It has to do with CEF and 16 hash buckets...
https://community.cisco.com/t5/routing/cef-load-sharing/td-p/2464585
would anyone know off hand what the
show ip gp
memory hashes in the above image mean?
Tonight i will send you case we use this hash.
Dont worry
