A rate limit question
Safar Safarov
I can manage the maximum limit of traffic speed with rate-limit command on my Cisco 2821 ISR, the question - is there any command to manage the minimum limit of traffic speed?
The case scenario (example):
I have 10 Mbps internet uplink, so I want to share it between two or more downlinks in the following manner:
The each downlink should operate at speed equal or more than 1 Mbps, but not less than 1 Mbps.
Thus, a minimum speed limit for each link should be set to 1 Mbps.
Is there any way how to do that?
Thanks.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
By downlink, if you mean ingress traffic, I'm unaware of a method to guarantee bandwidth (excluding limiting everything else).
If you mean egress traffic, CBWFQ can provide minimum bandwidth guarantees.  Traffic shapers or policers within a class can limit maximum amount of bandwidth consumption.
Joseph W. Doherty
Disclaimer
Posting
ashok_boin
Level 5
Level 5
As Joseph suggested, you can do with "bandwidth" commands on CBWFQ and apply service policy inbound on your ISR router interfaces toward your downlinks.
Regards...
-Ashok.
With best regards...
Ashok
