AAA and Local
korbenda11as
is it possible to enable both tacacs and local authentication? how this be done?
and what is the process whose gonna be the first?
network.king
Level 4
Level 4
Hi ,
You can enable both tacacs and local authentication.
aaa authentication login default group tacacs+ local
Whatever you have mentioned first , it would be considered . In case if not reachable then goes to the second one.
Hope this helps
regards
vanesh k
thanks! vanesh
