About NM-1A-OC3SMI and CBWFQ???
shan-cao
Hi,I want to confirm whether NM-1A-OC3SMI can support CBWFQ? Could you give me a response or give me a web link?Thanks for your help.
Sincerely
pkhatri
Level 11
Level 11
The NM-1A-OC3SMI does indeed support CBWFQ. The following link as more details:
http://www.cisco.com/en/US/customer/tech/tk39/tk824/technologies_tech_note09186a0080094b48.shtml
Pls rate the post if it helps.
Paresh.
Hi,Thanks for your help.Does the atm sub-interface support the CBWFQ?
Sincerely
Hello again,
Yes. The way it works is that a separate hold-queue is created per-VC. CBWFQ then works as a software queueing method before this hold-queue when there is congestion on the sub-interface (VC).
Pls remember to rate posts that help.
Paresh.
Hi,no problem.
