Bookmark
Subscribe
1678
About rtr.
stephtchoko
Level 3
Level 3
Good day
Please can somebody help me with configuration example on rtr protocol.
Best regards
cdfowlie
An example rtr config follows. This example uses rtr to check reachability of an IP address via ICMP. If the address is not reachable, the router then decrements the priority of HSRP on an Ethernet LAN interface. You can play around with the options, and if you let me know exactly what you are trying to accomplish, I can help further.
<----------SNIP----------->
rtr 1
type echo protocol ipIcmpEcho 192.168.254.1
request-data-size 1000
timeout 1000
threshold 500
frequency 5
rtr schedule 1 life forever start-time now
track 3 rtr 1 reachability
interface GigabitEthernet0/1
ip address 192.168.5.2
standby 1 ip 192.168.5.1
standby 1 priority 105
standby 1 preempt
standby 1 track 3
<------------SNIP--------->
You can use "show track", "show rtr config" (check "show rtr ?" for other options) and "show standby brief" to observe the effects of this configuration.
-CF
I need to configure backup link on broadcast (ethernet interface).We have 3 routers; RTA, RTB et RTC.
RTA is serie cisco 831
RTB is broband cisco UBR 7246 (but the interface cable of UBR 7246 can't support vrrp)
RTC is serie cisco 1710
RTA can reach RTC directly or via RTB.
the fist priority route will be via RTB and the second priority will be direct.
I need to configure it with rtr, beacuse hsrp and vrrp are not support by UBR7246 on interface cable.
thank you.
Stephane.
