12-22-2008 10:37 AM - edited 03-04-2019 12:47 AM
we are using a monitoring tools that report any thing that happens on the network,,, in this event code handler I got
ABR=83% ( threshold=99%)
my first question what does this mean
second what cli should I use see this on the router/switch
12-22-2008 10:42 AM
I do not think that we can answer your question without more context from the monitoring tool. It might be logical to assume that ABR is Area Border Router (are you running OSPF on this router?) but there is certainly not enough information in what you have posted to know what is happening 83% of the time.
Rick
12-22-2008 10:44 AM
yes we are using ospf .. what other info do you need .. here is an other one
Serial1/0 reported Link Availability = 0% (Threshold = 99%)
Thanks Rick
