Showing results forĀ
Search instead forĀ
Did you mean:Ā
access list and nat
eonhanif09
hi guys i really need some help on this
im trying to write this configuration that for a cisco 1800 router to allow access to given list of websites after writing the access list
and applying ii it kills my connection to the out side world below is the configuration, can some one please help  ?
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.200.9.62
ip dhcp excluded-address 10.200.9.126
ip dhcp excluded-address 10.200.9.190
ip dhcp pool TEST1
   network 10.200.9.0 255.255.255.192
   default-router 10.200.9.62
   dns-server 4.2.2.1
ip dhcp pool TEST2
   network 10.200.9.64 255.255.255.192
   default-router 10.200.9.126
   dns-server 4.2.2.1
ip dhcp pool TEST3
   network 10.200.9.128 255.255.255.192
   default-router 10.200.9.190
   dns-server 4.2.2.1
interface FastEthernet0
no ip address
duplex auto
speed auto
interface FastEthernet0.101
encapsulation dot1Q 101
ip address 10.200.9.62 255.255.255.192
ip access-group 101 in
ip helper-address 10.200.9.1
ip nat inside
ip virtual-reassembly
no snmp trap link-status
interface FastEthernet0.102
encapsulation dot1Q 102
ip address 10.200.9.126 255.255.255.192
ip helper-address 10.200.9.66
ip nat inside
interface FastEthernet0.103
encapsulation dot1Q 103
ip address 10.200.9.190 255.255.255.192
ip helper-address 10.200.9.129
ip nat inside
interface FastEthernet0.104
encapsulation dot1Q 104
ip address 10.200.9.193 255.255.255.192
interface FastEthernet1
ip address 192.168.0.199 255.255.255.0
ip nat outside
speed auto
full-duplex
interface Async1
no ip address
encapsulation slip
ip route 0.0.0.0 0.0.0.0 FastEthernet1
no ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet1 overload
access-list 101 permit tcp 10.200.9.0 0.0.0.63 host 66.225.150.110 eq www
access-list 101 permit tcp 10.200.9.0 0.0.0.63 host 64.34.146.188 eq www
access-list 101 permit tcp 10.200.9.0 0.0.0.63 host 38.99.141.53 eq www
access-list 101 permit tcp 10.200.9.0 0.0.0.63 host 72.8.141.90 eq www
access-list 101 permit tcp 10.200.9.0 0.0.0.63 host 69.90.78.232 eq www
access-list 101 permit tcp 10.200.9.0 0.0.0.63 host 207.66.153.26 eq www
access-list 101 permit tcp 10.200.9.0 0.0.0.63 host 107.23.157.221 eq www
access-list 101 permit tcp 10.200.9.0 0.0.0.63 host 142.20.63.115 eq www
access-list 101 permit tcp 10.200.9.0 0.0.0.63 host 204.225.34.63 eq www
access-list 101 permit tcp 10.200.9.0 0.0.0.63 host 204.41.8.16 eq www
access-list 101 permit tcp 10.200.9.0 0.0.0.63 host 66.225.150.66 eq www
access-list 101 permit tcp 10.200.9.0 0.0.0.63 host 216.201.100.110 eq www
access-list 101 permit tcp 10.200.9.0 0.0.0.63 host 107.6.25.151 eq www
access-list 101 permit tcp 10.200.9.64 0.0.0.63 eq www any
access-list 101 permit tcp 10.200.9.128 0.0.0.63 eq www any
access-list 101 permit tcp 10.200.9.192 0.0.0.63 eq www any
5 Replies 5
John Blakley
You'll need to allow dns as well. Add:
access-list 101 permit udp 10.200.9.0 0.0.0.63 host 4.2.2.1 eq 53
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
I believe that John has correctly identified a significant issue in the access list and it certainly needs to be addressed. I have a couple of other comments.
If access list 101 is applied inbound on interface FastEthernet0.101 then all of the source addresses should be in subnet 10.200.9.0. So these lines in the access list will never match any traffic
Also I notice that 3 of the interfaces have ip helper-address configured but the address specified in the helper address is in the local subnet. So the helper addresses will not be effective.
I would also comment that the static default route points just to the outbound interface. While that is fine if the interface is piont to point serial it can raise problems when the interface is Ethernet. So I would suggest that the default route should specify the next hop address.
Rick
Rick
i love this place, this is my first time here so let me say thank you to all you guys, i will look into this right now, i have my router and switch with me i will make these changes right now.
Alright guys so i made changes to the following codeing it is a little different than before;-
so the whole idea for this set up is that i want to beable to give clients on the 10.200.9.0 subnet internet access to only to the provided web sites anything thats out side of that the page would not load. The clients that are on the 10.200.9.64 and 192 network should have full access to the internet, below is the rewritten code.
The problem that i am running into is that the 10.200.9.0 subnet the pages take too long to load and times out.
Also Mr. Burts you stated that the helper address would not be effective (im a bit confuse on that part) should i have an access-list statment thats states "access-list 101 permit udp 10.200.9.1 0.0.0.0 (not sure from this point)"
ip cef
ip dhcp excluded-address 10.200.9.194
ip dhcp pool test1
   dns-server 4.2.2.1
ip dhcp pool test2
   dns-server 4.2.2.1
ip dhcp pool test3
   dns-server 4.2.2.1
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat inside
encapsulation dot1Q 104 native
ip address 172.27.69.125 255.255.255.0
ip nat outside
speed auto
full-duplex
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface FastEthernet4
shutdown
interface FastEthernet5
shutdown
interface FastEthernet6
shutdown
interface FastEthernet7
shutdown
interface FastEthernet8
shutdown
interface FastEthernet9
shutdown
interface Vlan1
no ip address
interface Async1
no ip address
encapsulation slip
ip route 0.0.0.0 0.0.0.0 172.27.69.254
no ip http server
ip nat inside source list NATLIST interface FastEthernet1 overload
ip access-list extended NATLIST
permit udp 10.200.9.0 0.0.0.63 host 4.2.2.1 eq domain
permit tcp 10.200.9.0 0.0.0.63 any eq www
permit tcp 10.200.9.128 0.0.0.63 any eq www
permit tcp 10.200.9.192 0.0.0.63 any eq www
permit tcp 10.200.9.64 0.0.0.63 any eq www
access-list 101 permit tcp any host 173.194.37.130 eq www
access-list 101 permit tcp any host 38.99.141.53 eq www
access-list 101 permit tcp any host 170.6.25.151 eq www
access-list 101 permit tcp any host 66.225.150.110 eq www
access-list 101 permit tcp any host 216.201.110.110 eq www
access-list 101 permit tcp any host 66.225.150.66 eq www
access-list 101 permit tcp any host 240.41.8.16 eq www
access-list 101 permit tcp any host 204.225.34.63 eq www
access-list 101 permit tcp any host 142.20.63.115 eq www
access-list 101 permit tcp any host 107.23.157.221 eq www
access-list 101 permit tcp any host 207.66.153.26 eq www
access-list 101 permit tcp any host 24.156.130.10 eq www
access-list 101 permit tcp any host 69.90.78.232 eq www
access-list 101 permit tcp any host 72.8.141.90 eq www
access-list 101 permit tcp any host 209.250.137.43 eq ftp
access-list 101 permit tcp any host 206.162.130.79 eq www
access-list 101 permit udp 10.200.9.0 0.0.0.63 host 4.2.2.1 eq domain
Thank you again for all the Help!!!!
The first issue that I notice is in your address translation. You have a permit for subnet 10.200.9.0 for DNS. But none of the other subnets have permit for DNS. So no other subnet will be translated when they attempt to get to the DNS server. So your other subnets will be able to access things by IP but not by name.
How can I help you understand helper addresses better. The function of helper address is to take a local broadcast and forward it to somewhere outside of the local subnet. But your helper addresses each has an address that is in the subnet in which it is configured. For example the first one is
But it is already in subnet 10.200.9.0. So 10.200.9.1 will already receive the broadcast. So why do you need helper address here? Perhaps if you tell us what you are attempting to accomplish in using helper address then we might be able to suggest how to accomplish that intention.
Rick
Rick
